Ok, Let me explain this as best as I can.
I have 2 4 channels, both mounted to my amp rack, I have them on 2 distro blocks for power and ground(1/0in and 2 4ga out)
I have engine whine pretty bad, and have tried almost every trick in the book.
First off, I am not running a headunit right now, just iPod into the EQ.
The amps are grounded roughly 3ft directly to my 2nd battery.
The EQ is grounded the to chassis
If I unplug the RCA's out of the amps, the engine noise stops
I have tried a new set of RCA's, notta
Power and RCA's are ran on the opposite sides of the truck
I purchased a Stinger ground loop isolator from Darvex, still there and noticeable.
Now, in all reality, Im sure the engine noise isnt that bad, but when you have 8 pro audio style 6.5s, everything's loud.
I can drown it out by cranking it up really high, but In my mind its still there.
I also have a train horn installed, and when the compressor kicks on, I can hear that through my speakers also(compressor is grounded to the frame of the truck.)
Any other ideas?
Edited by rival904
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
My guess is that right there. Take the RCAs from your iPod out of the EQ and see if it stops.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
So I bypassed the EQ(my HU is in for repair right now sooo), and the engine noise stops completely.
If I unplug my Ipod, and have the RCA's just hanging out of my dash, theres engine noise, but as soon as I plug something in, engine noise is gone.
Now, should I RMA my EQ, or do you guys not think the EQ is at fault?
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
Do you plan on adding a headunit? I would try that before assuming the EQ is bad.
F150:
Stock :(
Processor: DSR1
Ive tried 2 diff grounds for the EQ.
I should add that with the ipod into the amps, theres no engine noise, if I put the stinger ground loop isloator inline with the ipod, engine noise is back.
Yes, hopefully will have my headunit back in a week or so.
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
do you have access to another eq to pop in there and try?
sounds like the eq may be the problem, but wont know for sure till you put a headunit in there.
thats my guess anyways.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
