Fi Car Audio
whats a good amp for 2 15" btls
Canuheminow
i was wondering what amp or amps would be good on 2 btls? would a 300 amp alt and 3 d3100's be enough for a t4000.1? and also would 2 Audioque 2200D's be good? since there alot cheaper!
Chrysler 300 on 24's
(2) audioque 2200d's [subs]
(1) audioque 4x90 [highs/mids]
(2) 12" DC audio level 4xl's
(2) xspower D3100's
Iraggi 320 amp alt
Big 3, 2 runs of 1/0 guage
Box 4 cft tuned to 30hz
How about an IA 40.1? :)
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
two audioque 2200's would work fine. i would prefer them over the rockford since you could strap them and get more power at a higher ohm load (strapped at 2 ohms)
this would give you a more efficient setup and you wouldn't have to run as many batteries as the t4000 at 1 ohm
3 d3100's should be fine with a 300 amp alt.
ok kool, would there be a difference if i ran 1 amp on each sub at 1ohm or if i strapped them?
(2) xspower D3100's
Iraggi 320 amp alt
well would 1 AQ3500D at .5 ohm put out more power than those 2 aq2200's straped at 2ohms?
(2) xspower D3100's
Iraggi 320 amp alt
i personally would much rather have the 2 aq2200's.
alot more options for wiring.
you can get about 4000 watts at 1 ohm (2000 a piece). a little more than the AQ3500d at .5 ohms
and you can get about 4000 at 2 ohms when you strap them.
strapping at 2 ohms is also alot better for the amp then running at .5 ohms
also i would strap the amps instead of one amp per sub... because if you strap them then you only have one amp to tune. But if you had to amps to tune getting them exactly the same would be nearly impossible and im sure strapping them you'll get around 4500 watts those amps are beast
Johns.jpgSuburban Coming Soon
Strapping the two would be more efficient.Running a 2 ohm load on the two amps you will get better efficiency versus a 1 ohm load and you will have many different options for wiring if you decent to change it up in the future.And three 3100's and a 300 amp alternator should do just fine to keep up with that setup, provided the alternator puts out decent numbers and the RPMs when you play it.
The 2 AQ 2200s will take up more space but be more efficient. However the 3500 will take up less space and run at 1 ohm. Even though I hate strapping amps due to a bigger footprint, if you can spare the room go for it
2003 CHEVY TRAILBLAZER
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
2 Big Rear Batteries
A 38 HZ Box
KICK ASS!
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
