Okay I am just about stumped on this one. I am doing almost the same score at half volume as I am at full volume.
Only think I can think of is when I burp at half volume my rear hatch flexes but isnt too bad. When I burp at full tilt i can literally feel the air come out from the hatch flexing like 5 ft away.
I am decently happy with my score, but I feel I could get alot louder with out all the flexing.
Beside moving the latch so it closes tight (already done) is there any thing you guys would suggest. I don't care how loud it is out side, I am trying to contain as much pressure as I a can.
No cement!
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
back hatch is about as deadened as it can get, almost 30sq feet of dynamat, and I dont see how spray foam will help, metal isnt flexing, the hatch it self as a whole is.
And if your talking about the weather stripping is good as new.
*1) AudioQue 20k
u check for clippage yet?
brace the hell outta it and maybe add new latches and gaskets.
Voltage is crap at full tilt, but i don't think it clipping, but even if I am i am still losing alot of pressure.
How would you suggest bracing it?
Maybe a Linear actuator? to pull the hatch real tight?
Edited by Bigg Boy
*1) AudioQue 20k
if voltage is crap at full tilt then your loosing power on top of pressure.. take a buddy with you and have him press against the glass during metering.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
tried that didn't do much, not much you can holding it does, plus we where pushing so hard I am afraid of denting it.
I am waiting on getting my new alts in to correct voltage
Edited by Bigg Boy
*1) AudioQue 20k
well if your pushing on the hatch where its flexing and loosing pressure then your not loosing pressure anymore from that area so your lack of db increase is due to your voltage drop/box rise and your amp making less power.
Edited by chewie
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
I am saying even with pushing on the hatch, you still can't keep the pressure from escaping out between the hatch.
I know my voltage is alot a problem, but I cant fix that intil I get my alts in.
I really liking the actuator idea to shut the hatch, then pull it super tight. might be worth a try
Edited by Bigg Boy
*1) AudioQue 20k
Your not losing that much pressure from your hatch. I can burp my ZX3 with the hatch not even completely latched and I only drop by about .7db's. I found this out because there are some little rubber stopper type things on my hatch that were sticking out way too far from vibration I guess and didn't allow the hatch to completely close. Once I tighetend them back up the score jumped up by .7 db.
I would also be willing to bet that since your volatge is dropping so low that is what is not letting you achieve the output you should be. What does your voltage drop to when you burp the car? What amps are you running and what does the electrical consist of? If you say stock alternator and you are running over 3K watts then I promise you that is the first thing you need to address more than some air leaking out the hatch.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
