Burbarry Posted December 1, 2009 Report Posted December 1, 2009 There is a lot of good info on here, but not much in the way of actual results. So here is the products that I have ran Dynamat Original, Dynamat extreme, Edead, Fatmat, Fatmat Xtreame, Fatmat Rattle trap XXX, Zilla mat, B-Quite, hushmat, and now Second Skin. Dynamat original is good but you have to it to get it to stick, but once in place it is good to go. I would not use this on roofs, or trunk lids, or doors, just on you floors. No mess at all with this stuff. Dynamat Extreme works great can be installed any temp sticks great. This stuff can be messy while installing, and will cut you up pretty good since the metal backing is so thin. Edead do not recommend this stuff is asphalt needs to be heated up to stick, and falls when it gets above 100 degrees outside. This stuff can be messy while installing. This stuff can be messy while installing. Fatmat do not recommend this stuff is asphalt needs to be heated up to stick, and falls when it gets above 100 degrees outside. This stuff can be messy while installing. This stuff can be messy while installing. This is the same stuff as Edead, maybe a little bit better quality in the foil, but that is it. Fatmat rattletrap XXX is ok but still do not recommend this. You will have to heat this up to get it to stick good, as it is half butyl and half asphalt. But, it holds up in 100 degree temp outside. But if it is above 100 degrees outside for long periods like 12 hours in the sun, it will start to sag in places. This stuff can be messy while installing. Fatmat extreme works great can be installed in any temp. Sticks like a SOB. It is almost impossible to get it off when it is stuck to metal, and forget it if you stick it to its self. Zilla mat do not recommend this stuff is asphalt needs to be heated up to stick, and falls when it gets above 100 degrees outside. This stuff can be messy while installing. This stuff can be messy while installing. This is the same stuff as Edead, someone told me that is the same company just a different name used on packaging. B-Quite is ok but still do not recommend this. It is almost the exact same thing as Fatmat rattletrap XXX. You will have to heat this up to get it to stick good, as it is half butyl and half asphalt. But, it holds up in 100 degree temp outside. But if it is above 100 degrees outside for long periods like 12 hours in the sun, it will start to sag in places. This stuff can be messy while installing. Hushmat is good can be applied at any temp. Unlike most companies that bounce the sound back at you and can help gain you DBs on the microphone. This one does not increase your sound it actually absorbs sound. This stuff can be messy while installing. Second Skin works great and can be installed at any temp. This stuff sticks just as good as, if not better then the Fatmat extreme. The nice thing about this stuff is that it has easy clean up and no mess left behind. Plus it is thicker than any of the other mats that I have mentioned. In comparison to Dynamat it is about 1.5 times thicker, so 2 layers of this is like 3 layers of Dynamat. IMO, I would have to say that Second Skin takes the cake when it comes to sound damping material, for all bang for your dollar. I would have to say that Fatmat extreme is in close second, with Dynamat Extreme in third, and in forth would be Dynamat original but only if used on floors. As for the rest mentioned please don’t waste your money to save a buck or two. Spend a little more and get something that works good the first time around. I know that there is a few that have not been mentioned, but I have not personally tried them. Right now I will only be using Second Skin in all future installs, as well as cars I do for someone else. I am tired of helping someone put in cheap product and to have them come back a month later saying I did something wrong, because it is now sagging down. Chrysler 300 on 24" Menzari's Alpine 9887 CD player Sundown SAZ-1500, and 3-10" SA's wired to .667 ohms My Current Build log http://www.stevemeadedesigns.com/board/topic/137773-burbarrys-chrysler-300-walled-off/
Marlo Stanfield Posted December 1, 2009 Report Posted December 1, 2009 I think that there is very little dispute what company makes the best quality deadener out there... Second Skin Damp Pro is the best deadener is every facet that I've ever used. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
thehoe92 Posted December 1, 2009 Report Posted December 1, 2009 I think that there is very little dispute what company makes the best quality deadener out there... Second Skin Damp Pro is the best deadener is every facet that I've ever used. x2 I love it, I wouldn't use any other brand Wouldnt be thehoe92 without teh purple
Mosin Posted December 1, 2009 Report Posted December 1, 2009 But out of all the brands listed, which takes the cake for 'Best bang for buck deadener?' Derp.
Nightshade Posted December 1, 2009 Report Posted December 1, 2009 Not that it really matters but Edead is not asphalt based like you have listed. It is butyl rubber just like Second Skin or Dynamat Extreme. It has a mylar type foil on the outside and is why it pretty much just sucks ass. There is no doubt that Second Skin is by far superior, but if your going to post a review with the make up of the deadener make sure your facts are correct first. This info was coppied right from the Elemental Designs site: eDead Type eDead v.2 Mat Product Thickness 40-45 mils Heat Tolerance Industrial Core Layer Butyl LiteWrap Backing Yes Self Adhesive Yes Heat Gun Required Application Temperature 50+ DF Multiple Layer Capable Yes 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Cr@sh Posted December 1, 2009 Report Posted December 1, 2009 Has anyone done a db test like they used to back in the day? I'm just curious becuase to me in order to prove one is better then the other that would be the only true test, unless there's another way that would show scientific evidence? Not trying to start a fight but it's like when people say an amp wont do rated but they judge that by ear??? My old install at cardomain, never finished!
