tobio19 Posted December 5, 2009 Report Posted December 5, 2009 hey everyone, im going to be replacing my current sub and amp setup with something much more powerfull and just seeing what a good amp would be to run this sub, you all know it hehe. Fi 18" btl 2000w RMS Specs - Dual 1 Ω / Dual 2 Ω 1.4 Ω / 2.8 Ω 31.9 Hz / 31.1 Hz 6.26 / 6.42 0.26 / 0.24 0.25 / 0.26 313 g / 329 g 1210 cm2 163.1 l 94.9 / 94.9 1W/1m 18.33 / 27.2 Tm 16mm (SPL) 28mm (Daily) 2000W im getting this sub imported from the UK,, thru BladeIce (thanks Steve) so ive had a look at some amps to run it, since im in Australia I would have to import it. 1st amp idea - Sundown Audio SAZ-1500D specs - Double Sided Through Hole Epoxy PCB Efficiency : 86% @ 4 ohm, at 100Hz 24dB/Oct Variable Crossover Multi-Way Protection Circuitry (Thermal/Over Current/Speaker Short/Speaker DC Protection) Variable Subsonic Filter Variable Bass Boost Variable Low Pass Filter Variable Phase Shift Zero(0) Gauge Power Supply Connectors Tested Voltage & THD : 14.4V & Less than 1% THD Operating Voltage : DC 10V~18V Digital Class-D Linkable Mono Block Amplifier 1 Ohm Stability RCA Line Input and Master Output 24dB Octave Crossover Slope Wired Remote Controller Rated power output ----RMS power, 2 ohm linkable/dual mono 3000W x 1CH ----RMS power, 1 ohm mono 1500W x 1CH ----RMS power, 2 ohm mono 800W x 1CH ----RMS power, 4 ohm mono 400W x 1CH Link to sites - http://www.audiojunkies.com/product/10/sun...az1500d-reviews http://www.sundownaudio.com/index.php/prod.../saz-1500d.html Price - not 100% sure but around $600au 2nd amp choice (this one I can buy here where I live) JL Audio G-MAX Class D Monoblock 1200W specs - ated Power 14.4 V: 600 W RMS x 1 @ 4 ohm 1200 W RMS x 1 @ 2 ohm Rated Power 12.5 V: 450 W RMS x 1 @ 4 ohm 900 W RMS x 1 @ 2 ohm THD at Rated Power: <1% THD, 20 Hz - 250 Hz S/N Ratio: >90 dB referred to rated power (A-weighted, 20 Hz - 250 Hz noise bandwidth) Frequency Response: 10 Hz - 250 Hz (+0, -1dB) Damping Factor: >500 @ 4 ohm / 50 Hz >250 @ 2 ohm / 50 Hz Input Range: 200mV - 8V RMS Dimensions (L x W x H): 15.75 in. x 9.25 in. x 2.50 in. 400 mm x 235 mm x 63.5 mm link to site - http://mobile.jlaudio.com/products_amps.php?amp_id=476 Price - $450 - $500au So what do you guys think,? thanks again, 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
OBI Posted December 5, 2009 Report Posted December 5, 2009 Niether, seeing as that both will even give the sub it's rms. Get the Sundown 2000 at least.
Skullz Posted December 5, 2009 Report Posted December 5, 2009 http://www.audioque.com/aq/?page_id=28 350 shipped EDIT: missed the australia part so i dont know what shipping would be there. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
tobio19 Posted December 5, 2009 Author Report Posted December 5, 2009 http://www.audioque.com/aq/?page_id=28350 shipped EDIT: missed the australia part so i dont know what shipping would be there. wow, thanks m8, thats a lot of power for that small price,, looks good, do you guys recomend that?. 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
Bigg Boy Posted December 5, 2009 Report Posted December 5, 2009 i run them, and honestly one of the best amps I have run Dodge Magnum with custom 300c front end, laid out on air bags *4) 12" Cadence Daytona walled *1) AudioQue 20k *270a DC Power Alt (Dual coming soon)
Marlo Stanfield Posted December 5, 2009 Report Posted December 5, 2009 wow, thanks m8, thats a lot of power for that small price,, looks good, do you guys recomend that?. Without question... All the AQ amps are very well built and will do rated power. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
tobio19 Posted December 5, 2009 Author Report Posted December 5, 2009 Without question... All the AQ amps are very well built and will do rated power. thats great!, all I needed to know, ill contact them and see if they import, thanks again for helping me out! 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
