The bd sync cable is for strapping,but u can still master 1 amp & slave another without strapping them.The bd cable connects a pair of amps to act as one big amp but is only 'RATED' stable at 2ohm total load for the pair.
please take this to a discussion in the amp section. This section is for "for sale" discussion only.
Thanks
-Chode
NoFearX18 said:
Thanks
-Chode
Someone slap this dude upside his head.
B)
All you have to do is set the first amp to master and your rca from the head unit of course go to that amps in, then set your second amp to slave and the outputs of the first amps go to the inputs of the second amps only the controls on the first (Master) amplifier need to be set.The gain on the subsequent (Slave) amplifiers can be used for fine-tuning. and each amp can accept its own 1 ohm load. ;)
EXACTLY....
Hey this is good info someone needs to make a thread about master/slave config in the Rockford Section....it sounds confusing but its actually about as easy as it gets and is the BEST feature ive seen on an amp in a long time. Thanks Rockford for making my multi-sub world easier to deal with!
Follow my Tweet (Twitter)
I gotcha covered Steve! I pretty much JUST had my 2nd T1000 delivered about 5 minutes ago, so now I just need to know how to hook them up the way I want.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
