here is an overall pic of stereo
here is pic of tape/eq
pic of it out.
the problem is : #1. there is not a plug . its hard wired . to where i dont know.
common sense says to the main part of the head unit but when i
remove the dash face plate and try the main unit only comes
foreword about 2 inches. so i cant see/feel to unplug it.
#2. do i have to remove both main and tape/eq? "gotz1lung"
in his build only removed the tape/eq part. i pmed him but
received no response. 1992chevyk1500 found the harness and
face plate for me(thank you)but am having a hell of a time gettin
this figured out.
thanks for any/all help
matthew
sony m60ui
polk mid/hi's
infinity 6000m on tower
fosgate p3d212 x2
fosgate p400-4
fosgate t1000-1bd
im ona boat bitch
My boat build
funny thing is...............slamming fireworks in to the ground with a sledge hammer in mexico is like car audio in california... everyone is doing it but most fail :)
Every time I read a comment you post, or a topic you make... I cannot help to think of how much of a badass you are!!
pic of it out.
this figured out.
matthew
above the gas pedal the brain is there. I believe it is a single 7 mm holding it up... but it has been a long while
Edited by North Olmsted Performance
SMD SuperSeller VerifiedJbondoXJames Shields
ok found it . turned stereo on and unplugged both jacks and
radio was still playin(hahaha) but all lights went out/memory was gone.
so do i unplug them there and just remove them from the dash?
then use harness to get to stock speakers? :unknw:power/ground
Edited by az73
sony m60ui
polk mid/hi's
fosgate p3d212 x2
fosgate p400-4
fosgate t1000-1bd
im ona boat bitch
My boat build
if you go to the12volt.com they have a wiring diagram section for the vehicles it has pretty much everything u would need to know about it..
95 Delta 88
10 inch fubar(2 MB Quart RWE-352 15" on way soon)
1500.1 crunch
kenwood KDC-MP642U
Jp Kustomz
They are a bit of a pita. All the plugs you need are on the "brain" above the gas pedel. You un hook them, plug them into a metra 70-1858, then pull the wires back up to where the aftermarket h/u installs. then wire the h/u plug to the 70-1858 in the dash, not out out the truck like I normally do, because once you pull the plugs over the dash support bar, it gets a bit tight putting everything back in. so I leave them under it. youll have a plug that is unused, its the one that runs up to the radio tunner in the bezel
Edited by baggedon4s
99 suburban, ranger rover headlights, SS front bumper,roll pan with frenched tag, 2nd row delete,glassed dash..audio to come whenever I figure out what I want.
pic of it out.
this figured out.
matthew
When I did my 91 Chevy, I pulled them both but didn't have to cut the wires off the EQ... There were plugs there. When you install your aftermarket HU it will go where the EQ was. I actually think I still have one of those install pieces somethere... Also when I did my 91, Crutchfield sent me a pocket that goes where the stock HU went... It was a PITA but well worth it...
2011 Dodge Durango Citadel AWD HEMI - LOADED
Stereo:  STOCK
Emergency Equipment:  Morotola - Federal Signal - Feniex - Gamber Johnson
Performance:  MOPAR Performance - Diablo
911 Calltaker / Diaptcher, Volunteer Ambulance Driver, Rescue Tech, Fire Fighter, Fire Policeman, Emergency Equipment Installer / Repairman
thanks guys appreciate all the info
matthew
sony m60ui
polk mid/hi's
fosgate p3d212 x2
fosgate p400-4
fosgate t1000-1bd
im ona boat bitch
My boat build
Holy shit that brings back memories of when I first started installing... I remember the guy that was training me said "well i'm gonna let you just give this one a whirl and see how long it takes you to figure it out"... being a cocky teenager i was like "got it!"... hahah took me like a half hour to figure out the brain was down by the gas pedal.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
i love that button....it was my best friends.he shot himself a couple
of yrs ago and it just reminds me of him. its in my work truck and
we both have the same businesses.
shit ive tried for hours but cant even get to the back of the main
unit to see if theres a plug. the tape deck part is hard wired so
when i tried to follow those wires they just disappear into the loom
somewhere. since its my work truck i didnt want F anything up. :01nocomment8so:
sony m60ui
polk mid/hi's
fosgate p3d212 x2
fosgate p400-4
fosgate t1000-1bd
im ona boat bitch
My boat build
