I have a pair of Kicker CVX 12s. The website has a maximum vented airspace of 2.25cuft and a maximum sealed airspace of 4.6cuft. First off those numbers almost seem backwards to me. Then I have seen people with enormous enclosures. Why would I want to build an enclosure to lets say 4cuft for a ported enclosure assuming Im just using one sub? And also what would be the difference in me building lets say a 2cuft sealed enclosure versus the 4.6cuft enclosure again assuming im using one sub.
You worded this horrible, prolli the reason why no one has responded so far... How many woofers are you using?? and what amp(s) are you gonna be running?? How much space do u have available to use??
Pioneer AVIC-N2
Hes got a pair, 2, of CVX 12s, first and only full sentence i read. After that i looked but ya, poorly worded. What are you asking exactly OP?
But he said using only one which confuses me.
Edited by siucsaluki11
Ok well first off I wasnt needing advice on how to design a box. I was just wanting to know why would you build a box bigger than manufactor specs. But I currently have 2 12" Kicker CVX subs and Hifonics Brutus BXi2006D. My current box is 4.5cuft @ approx. 33Hz. And I have a tahoe so size isnt an issue, just wondering why would one build the box bigger.
with kicker they dont sound the greatest sq wise but i would still do a ported enclosure
95 Delta 88
10 inch fubar(2 MB Quart RWE-352 15" on way soon)
1500.1 crunch
kenwood KDC-MP642U
Jp Kustomz
More power your pushing (at rated, or above) = Smaller box
Less power your pushing (below rated) = Bigger box
That is the reason people build bigger boxes. Idk if that's exactly what you are asking, but that is to answer the bolded.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
I kinda of had to find this out the hard way with my 15 type rs. I was surprised to see alpine saying 1.75 for sealed and 2.25-2.5 ported. Well I built a ported box specs you can see in my sig and they get loud but can do alot more.
Manufacturers dont always give you the best specs I guess. I will be redoing my box and probably adding more power after this winter. Like Klown said less power bigger box more power than rated smaller box. my type rs are rated 750 rms but can take much more than that so I am underpowering them and they are in a box too small to begin with. My advice is I'd just listen to the dudes here that know what they are talking about because I tried to save money and do it my own way and I shorted myself and now Im just going to upgrade anyways, I should of just done it to begin with but hey, lesson learned.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
I would call the tech rep and find out what he recommends.
2017 Chevrolet Silverado LT CC - Will be running 2-3 DC Audion M3 8s, unsure of amp, Mechman 320 amp alt.
2005 Ford F150 - Bagged on 24s, fully shaved, raised bed floor.
