Oh....my bad...was looking at the wrong sig info...lol....i was talking about the Treo's
can i drop them to .5 their dual 4?
Vehicle: 2003 Lincoln Navigator
Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust
Amplifiers:Kicker Kx2500.1, MA Audio M700XE
Batteries: 1 Kinetic Hc2400 Battery
Electrical: STOCK Charging System! Tsunami 40farad Capacitor,
Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz)
Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter
Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter
Subwoofers: 2) 15 Power Acoustik Mofo
Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable
Video: http://www.youtube.com/2treo15
I think you should just get a more powerful amp at 2ohms since it would be less stressful on your electrical system, but that's just me.
Edited by Berto
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
you need to figure out what your getting for power now and what your imp rise is, you could always get another amp and run them at 1ohm 1 per sub and gain match them, but by the sounds of it you really dont know much about audio in general (not sayin that in a bad way) but thats how it seems. As said 0.5 is tough on electrical you need to understand a few things though current draw of the amp, voltage dip, output of the alt and take into consideration what you will need for overall power, the kinetik site is nice because they have the calculator on there for this very reason. Also replacing the stock battery is almost always a nice increase...
Why? He said theyre D4, you cant get a 2 ohm load. You can get 1 or 4. If they were D2 you could get .5 or 2 for the pair. So...If his subs are D4 he should look at an amp that is 1 ohm. I learned the hard way when i bought my subs. I bought 2 D2s, thinking i would run them both off diff amps, then got amps that werent 1 ohm stable. Ended up running them both off a 2 ohm stable amp that put out more power.
