Bumpindemlowzz Posted December 13, 2009 Report Posted December 13, 2009 Anyone have any experience with the incriminator 20.1 amps? Do they put out more then rated? Digital Class-D Linkable Mono Block Amplifier Exclusive Bullet Proof Technology Layering Daisy-Chain Through Output RCA for Strapping 1 ohm Stable and 2 ohm Stable when Strapped Dual MOS-FET PWM Power Supplies 24 dB Low Pass (LPF) Crossover Variable - 35 Hz to 250 Hz 24 dB Subsonic Filter Variable - 10 Hz to 60 Hz Selectable Switch for Master and Slave Operation Multi-Layer Protection - Speaker Short, Over Current, Thermal, and DC Protection Circuit Line Input and Master Output / Slave Input RCA Connectors Heavy Duty Copper Layer Double Sided Epoxy PCB 0 Gauge Battery Input Connectors 8 Gauge Speaker Output Connectors 100% QC Testing and Warm Up Efficiency: 86% at 4 ohm, 100 Hz Tested Voltage & THD : 14.4V and Less Than 1% THD at 4 ohm RMS Watt Operating Voltage: DC 10V ~ 16V Power Input Damping Factor: 350+ into 1 ohm Input Sensitivity 200mV to 6 Volts Rated Power Output RMS: 3600 watts at 1 ohm Linked 1800 watts at 1 ohm 900 watts at 2 ohms 450 watts at 4 ohm 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
andym85 Posted December 13, 2009 Report Posted December 13, 2009 check out their forum on soundsolutionsaudio.com very good stout amps!!! i likes me some audio stuff...
Bumpindemlowzz Posted December 13, 2009 Author Report Posted December 13, 2009 check out their forum on soundsolutionsaudio.comvery good stout amps!!! would you think it would be comparable to a sundown 2000d? 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
Boon Posted December 14, 2009 Report Posted December 14, 2009 The old 20.1's were very very badass amps. And quite underrated as I understand it. Same amp as the Atomic AT2200.1 if that gives you any indication... 10.x volts fo' life!
Marlo Stanfield Posted December 14, 2009 Report Posted December 14, 2009 They're absolute beasts, IMO prolli the most bulletproof amps made today... They can handle just about any ohm load imaginable(I saw a pair burped @ .25ohm strapped, meaning .125ohms each) as long as you have the electrical and they will put up some huge numbers. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
Laronzo Posted December 14, 2009 Report Posted December 14, 2009 I run mine strapped at .5 daily without any problems, if I really pound on them they get a bit warm, but that is expected. I only have experience with the old 20.1s, but I hear the new ones are just as bulletproof with a bit more power in them. Good luck, Larson
