Could be a bad ground, could be too low of a ohm load for the amp to run. What kind of amp and sub(s) are you running?
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
IM RUNNING A SONY XPLOD 760W AND THE SPEAKERS ARE PIONEER 12'' I THINK THERE THE TSW306C I THINK THATS THE MODEL
By whole system do you mean radio and all or just the amp? If it's everything it is more than likely a voltage issue. I have had that problem at one point running two Alpine mrd-605's off a stock 650 amp battery and a single run of 4 guage. When the bass line would first hit the whole car would just shut off, engine and all since the voltage dropped so low. I measured it and I was dropping to the mid 11's, but for some reason it decided to shut off.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
you think that sony is pulling that much current? makes sence tho if everything is shutting off then coming back on. But like Klown said, if its just the amp then you need to check your ground. make sure its tight and make sure its clean of paint.. Also dont use all caps, all caps means yelling in a forum.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
How's the wiring in the box to the amp? Is the amp and sub refurbish or new?
yeah man i mean whole system radio and amp they turn off and come on right away and if i keep it at hte high volume it just turns off again right away not even two seconds could it be the radio thats going bad or wat do u think it could be
Passenger side back tire needs a bit more pressure. Should be set after that.
In all honesty, we need more details....type of equipment, how its setup. To help you trouble shoot.
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
well both are new the wires ive used before they are the wires for a one channel amp were its positive and negative only on the amp side and two + and two- on the speaker side hope u understand hope this lil pic helps
speaker a + and - + and - speaker b
1
1
1
1
amp + and -
