i am think bout purchasing one my buddy said the would increase SQ. how do they work and how do u install them?
New to the car audio world, and who ever said this is an addicting hobby they were right!!
a line driver increases the pre out voltage from the source to the amp. Its installed between the two ;)
depending on what head unit you have already you could be good to go already...a lot of these newer amps really dont need a shit ton of pre out to get to full potential.
Eclipse cd7000
Here you go:
http://www.stevemeadedesigns.com/board/ind...ghlite=%2BTLD22
I was very impressed adding the Phoenix Gold TLD22 to my last system and you should find alot of half decent info in this search.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Ill never run a line driver again. I had an AC 2XS. All it did was clip the piss out of my signal and make a god awful pop through my speakers when it turned on.
It never even boosted voltage that Im aware of.
Edited by TheSundownFire
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
did u try and read it with a DMM bruh ?
153.3 @ Turkey Drag 2009
Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!!
I never bothered. It had a readout for voltage boost on it. I just got tired of my highs sounding like crap and ripped it out.
The manual said it would boost up to 5v or something like that and my headunit does close to that.
Alpine CDA-9886
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
All I can tell you is if a line driver is used properly my experience shocked and surprised the heck out of me.
I love it when I don't expect much and the final results shock me to the point that I say WoW I guess its a good thing I made that change.
Find a good EQ. Can incrase voltage and make tuning your system to your sounds easier.
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
personally, my line driver (rockford rf-bld) made the biggest difference (a bigger difference than amps, components, or this damn top of the line pioneer deck)
it can do balanced or unbalanced outputs, aka, it can eliminate ground noise
depending on the setting it can do 11-22volts, aka, it lowers your noise floor to china
i installed it and retuned everything, and my horrible alt whine was gone, my hiss was gone, and everything sounded clearer and crisper than ever before. if you know what the defeciency in your system is, theres a way to fix it. if you just heard about a line driver and want your system to sound "better" it may not be for you. all it can do is increase dynamic range, lower noise floor, or eliminate interference if it has an unbalanced mode.
Team DC
