bcbrave Posted December 19, 2009 Report Share Posted December 19, 2009 i am think bout purchasing one my buddy said the would increase SQ. how do they work and how do u install them? Quote New to the car audio world, and who ever said this is an addicting hobby they were right!! Link to comment Share on other sites More sharing options...
finkster Posted December 19, 2009 Report Share Posted December 19, 2009 a line driver increases the pre out voltage from the source to the amp. Its installed between the two depending on what head unit you have already you could be good to go already...a lot of these newer amps really dont need a shit ton of pre out to get to full potential. Quote DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living Link to comment Share on other sites More sharing options...
ISO Posted December 20, 2009 Report Share Posted December 20, 2009 Here you go: http://www.stevemeadedesigns.com/board/ind...ghlite=%2BTLD22 I was very impressed adding the Phoenix Gold TLD22 to my last system and you should find alot of half decent info in this search. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
treossi Posted December 20, 2009 Report Share Posted December 20, 2009 nice i learned something too Quote Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details Link to comment Share on other sites More sharing options...
TheSundownFire Posted December 20, 2009 Report Share Posted December 20, 2009 (edited) Ill never run a line driver again. I had an AC 2XS. All it did was clip the piss out of my signal and make a god awful pop through my speakers when it turned on. It never even boosted voltage that Im aware of. Edited December 20, 2009 by TheSundownFire Quote 1999 Pontiac Sunfire Alpine CDA-9886 Sundown Audio SAZ-1000D Sundown Audio SAX-50.4 Rainbow SAC 265.25 Components Image Dynamics iD12 Optima Yellow Top SQFire FTW. Link to comment Share on other sites More sharing options...
DEEz NUTz Posted December 20, 2009 Report Share Posted December 20, 2009 Ill never run a line driver again. I had an AC 2XS. All it did was clip the piss out of my signal and make a god awful pop through my speakers when it turned on. It never even boosted voltage that Im aware of. did u try and read it with a DMM bruh ? Quote 153.3 @ Turkey Drag 2009 Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!! Link to comment Share on other sites More sharing options...
TheSundownFire Posted December 20, 2009 Report Share Posted December 20, 2009 I never bothered. It had a readout for voltage boost on it. I just got tired of my highs sounding like crap and ripped it out. The manual said it would boost up to 5v or something like that and my headunit does close to that. Quote 1999 Pontiac Sunfire Alpine CDA-9886 Sundown Audio SAZ-1000D Sundown Audio SAX-50.4 Rainbow SAC 265.25 Components Image Dynamics iD12 Optima Yellow Top SQFire FTW. Link to comment Share on other sites More sharing options...
ISO Posted December 20, 2009 Report Share Posted December 20, 2009 All I can tell you is if a line driver is used properly my experience shocked and surprised the heck out of me. I love it when I don't expect much and the final results shock me to the point that I say WoW I guess its a good thing I made that change. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
LoudBlazer Posted December 20, 2009 Report Share Posted December 20, 2009 Find a good EQ. Can incrase voltage and make tuning your system to your sounds easier. Quote 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350 Link to comment Share on other sites More sharing options...
raytard Posted December 20, 2009 Report Share Posted December 20, 2009 personally, my line driver (rockford rf-bld) made the biggest difference (a bigger difference than amps, components, or this damn top of the line pioneer deck) it can do balanced or unbalanced outputs, aka, it can eliminate ground noise depending on the setting it can do 11-22volts, aka, it lowers your noise floor to china i installed it and retuned everything, and my horrible alt whine was gone, my hiss was gone, and everything sounded clearer and crisper than ever before. if you know what the defeciency in your system is, theres a way to fix it. if you just heard about a line driver and want your system to sound "better" it may not be for you. all it can do is increase dynamic range, lower noise floor, or eliminate interference if it has an unbalanced mode. Quote Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
