Why is the clock + top cigg charger + side mirrors on my car not working? t
Check your fuses
I checked fuses and they were fine :(
I don't know wtf is going on.
I can't even adjust my side mirrors now because something is cut off.
Ideas anyone? Driving without being able to adjust the side view mirrors is a bit dangerous so I need to figure out how to fix this asap =[
Check fuses.
You adjust mirrors multiple times? Wow...
Check fuses.
I checked the fuses located in the money penny compartment driver's side and it was fine.
I checked all of the fuses under the hood fuse box and those were fine.
As for my mirrors, I adjust my seat every now and then that's why I need to adjust my mirrors. I ussualy have my seat all the way back and leaned towards the back so I can feel more bass when I'm driving but when I'm not in the mood for base, I move my seat up a little and drive properly -.-
It's just your aux fuse. Seriously. Get a test light and you'll find it pretty fast.
I'll probably just buy a new one and replace the old one and see what happens
  • 4 weeks later...
I"ve checked my fuses 6 times already and it's not the fuses.
Any other ideas why my Side mirrors + Top Cig lighter + Car Clock not working?
Is there a messed up relay or something? What else can I do to check?
This all happened when one day the male end of my garmin power charger was disembled and I didn't know so I kept trying to jam the thing into the ciggarette lighter trying to get my garmin gps to start up. Could it be a wire came loose somewhere behind the dashboard?
I agree with everyone that says to check fuses. This is the fuse block in the instrument panel. The blue colored one is for mirrors, cigarette lighter and clock. Should be a 15amp fuse.
have you taken your door panels off recently? that could also be the problem, cuz usally when you take the panels off theres a lil plug that hooks into where your mirror controls might be, and on a side note even though you have power mirrors you can still adjust them by hand -.-
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
1. turn the key to on
2. get a dmm
3.black lead to ground
4.take the red lead and touch both metal tabs at the top of the fuse's
5.the blown one will read 12 on one side of the fuse and 0 on the other. the fuse can be blown without looking blown
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
  • Who's Online   0 Members, 0 Anonymous, 501 Guests (See full list)
