how to measure RCA voltage?
well im having a problem with my current set up, and im looking at how to measure the voltage of my left RCA channel, and then the voltage of my left RCA preout on the back of my HU, how i can i do this?
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Look around and you will find.
Hint: Head Units-Proccessors and Eq's
Hint: Forum Topic
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Hint: Forum Topic
everytime i ask any question i get no answers
such as in this thread:
http://www.stevemeadedesigns.com/board/ind...mp;#entry888742
been days
Team Sundown Audio
outside of rca is ground... inside pin is positive
hence why the outside connection of the rca is always exposed, its a ground
thats what i thought but i tried that and got NOTHING
Team Sundown Audio
Heres what I did to hook up my RCAs to my Oscilloscope to check for clipping
Just get some cheap female RCA ends (http://exclusive-part.com/2rca-35mm_3.jpg)
Cut the end off so you are left with just the female connector and some wire, then strip that wire and separate the two conductors.
Now hook up your voltmeter to the two wires (positive or negative does not matter because we are metering AC and not DC)
Now play a 1khz test tone and see what voltage your deck cranks out .
Too Much Stuff to list .
ur deck will clip at different volume numbers depending on frequency, so check voltage at 8k for tweets, 1khz for mids and 50hz for subs
  • Who's Online   0 Members, 0 Anonymous, 1147 Guests (See full list)
