heres a good one !
Tooshort064
Alright i have 2 memphis mcd-1000's on a maxxlink.
When i was Adjusting the output of each amp I just about fell out of the car .
with the gain on each amp turned at 3 o clock I went from there.
I turned the 65hz test tone on the maxxlink on and ac voltage output on just 1 of these amps was 51.2 volts AC
but to my amazment it was just one it was both.
these amps are rated @ 1100 watts rms .
http://www.stevemeadedesigns.com/board/ind...showtopic=14543
now if going by the chart is correct how are these little things doing it ?
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
Clipped to fawwwwwwwwwk plus your DMM is reading peak not RMS.
So divide that by the square root of 2 and then turn them down until they're not clipping any more.
Voltage of an AC wave will rise considerably when the wave squares off.
In conclusion, not to burst your bubble but no, your amps aren't doing 2.7kw each ;(
10.x volts fo' life!
just because the gain is turned up that high does not necessarily mean that's the power it will put out. i could crank my 3500D's and if i went by output voltage alone you'd be amazed at what they'd say ;) with some massive clipping. if the amps didnt shut off before then
EDIT: ^^what he said :)
Thats why you set gains with an oscope.
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
  • Who's Online   0 Members, 0 Anonymous, 842 Guests (See full list)
