If you search the forums you'll see a ton of complaints about AIM. FBI should do you pretty good. if they don't have what you need pm me and ill get you set up.
  • 3 weeks later...
Big P,Meade.......anyone else with experience........what do ya think of this.........
http://www.airbagit-store.com/productImage.../U_assemble.jpg
http://airbagit-store.com/product_list.asp?id=2212
Yes please stay away from there bag struts.. They will not get you low at all. They just use a factory strut. Hit me up bro I own www.fmkustoms.com and we have done alot of those cars. Hit me up I would be glad to help you get all the parts you need and save you alot of cash.
  • 3 months later...
so its been forever and a day now......and Im seriously contemplating doing this.. Can we put together a list of what i need...
bags in the rear,
strut bags in the front
Tank
Compressor or 2
lines...and what else
ballpark figure.....how much will it cost me to build a kit
My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
about 2k maybee abit more.
you need at minimum a 5 gallon tank
8 valves
DOT fitting kit.
a good 100% duty cycle compressor
front strut kit
rear strut kit, (not 100% sure on your car)
possibly some metal fab parts
switch box
DOT lines
guages
145 to 170 psi switch
couple relays
thats the basic's of it
I needed some hard to find fittings (union 90's) they were fuckin expensive )
time, patients, and more time.
Ill pm you the prices But heres some stuff to think about
my catalogs don't have your car listed But heres some options
Air Cylinder 3.25 diameter x 4.75 stroke, Parker P1L equivelant works well on 88-00 Civic, CRX, Del Sol, Accord (1/2 port on top 2 3/8 ports on side 4 10MM mounting holes) NOT TO BE USED ON A MACPHERSON CAR
Air Cylinder 4 diameter x 4.75 stroke, 3/4-16 thread on shaft Parker P1L equivelant works well on 88-00 Civic, CRX, Del Sol, Accord (1/2 port on top 2 3/8 ports on side 4 10MM mounting holes) NOT TO BE USED ON A MACPHERSON CAR
100mm bore x 100mm stroke cylinder 4" X 4"
95-05 Chevy Cavalier strut kit front 1/4" ports
95-05 Chevy Cavalier strut kit rear 1/4" ports
Chapman Universal Strut Kit, Front or rear
McPherson Universal Strut Kit, Front
McPherson Universal Strut Kit, Rear
VIAIR 460C 8 3/8 VALVES 1 10 SWITCH BOX 1 PRESSURE SWITCH 110/145 1 RELAY 2 DUAL NEEDLE GAUGES 220psi 1 TANK GAUGE 200psi 50' 3/8 DOT LINE & 50' 1/4 DOT LINE 1 5 GAL AIR TANK 1 250psi SAFETY VALVE KIT
or
1 VIAIR 380C 8 3/8 VALVES 1 10 SWITCH BOX 1 PRESSURE SWITCH 145/175 1 RELAY 2 DUAL NEEDLE GAUGES 220psi 1 TANK GAUGE 200psi 50' 3/8 DOT LINE & 50' 1/4 DOT LINE 4 3.25"D x 4.75"S Air Cylinders 1 5 GAL AIR TANK 1 250psi SAFETY VALVE
you'll need to pick up fittings still.
Where could you mount all this shit gp? By the looks of it you're running low on space.
Edited by BassJunkie
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
