jcm1689 Posted May 22, 2007 Report Posted May 22, 2007 ok i dont know if this is possible or not but i need to know is there a way to run 2 inverted subs and 2 non invertes subs off of 1 2-Channel amp??? is so please tell me how.... i know from accidents if you mix up the the pos. and neg. speaker wire it reverses the phase but i dont think its good to run the speakers like that is it???? R.I.P. KOOLAID KING --- Thomas Johnson 04/02/1986 - 06/09/07 THUNDER CAR AUDIO Chris's 91 hatch - 2 18" BTL's, 2 T40001BD's, 153+ dbs Chris's 2005 BMW 525i Chris's 2002 Ford Ranger 2004 Silverado Blow Through 1999 Silverado - 4 15" SSD's Fiberglass Top Infinity G20 *RIP KOOLAID KING* Dodge Stratus - 2 12" Power HX2's, Fiberglass Baffle
audiofanaticz Posted May 22, 2007 Report Posted May 22, 2007 i know from accidents if you mix up the the pos. and neg. speaker wire it reverses the phase but i dont think its good to run the speakers like that is it???? Thats pretty much the only way to do it, unless you have 2 separate amps, 1 for the non inverted subs and 1 for the inverted subs with the phase on the amp turned to 180 degrees. The only thing that changing the pos and neg is going to change the phase, other then that the speaker cant tell pos from neg except for the phase being changed. Either way it will work and wont hurt the speaker or the amp.
Slinky Posted May 22, 2007 Report Posted May 22, 2007 it should work fine like that. either wire it like that or get 2 amps. DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
jcm1689 Posted May 22, 2007 Author Report Posted May 22, 2007 ok cool thanks guys. R.I.P. KOOLAID KING --- Thomas Johnson 04/02/1986 - 06/09/07 THUNDER CAR AUDIO Chris's 91 hatch - 2 18" BTL's, 2 T40001BD's, 153+ dbs Chris's 2005 BMW 525i Chris's 2002 Ford Ranger 2004 Silverado Blow Through 1999 Silverado - 4 15" SSD's Fiberglass Top Infinity G20 *RIP KOOLAID KING* Dodge Stratus - 2 12" Power HX2's, Fiberglass Baffle
