MickyMcD Posted December 26, 2009 Report Posted December 26, 2009 Ya i guess but if you look at the pics that second peak is still part of the sealed enclosure section since it is a fourth order bandpass. The way i designed it the back peaked section should act as a resonator and as part of the sealed chamber. Its gonna be interesting. I am afraid I cannot see what you mean, but that is just because I am having trouble interpreting the images. Cheers, Mick Work;DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS VeniceMeyer Sound CQ-1's, CQ-2's, PSW-2'sRAMSA Monitor AmplifiersP.Audio MonitorsBSS OMNIDRIVE and SoundwebDBX 231 and Klark Teknik DN360 EQ'sRCF TT22ARCF ART320
bcpballer64 Posted December 26, 2009 Author Report Posted December 26, 2009 I am afraid I cannot see what you mean, but that is just because I am having trouble interpreting the images. Cheers, Mick In the last picture listed that whole profile is sealed. The other part that show in the top couple of pictures is the ported side. Hope that clarifies. "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
HHR Ed Posted December 26, 2009 Report Posted December 26, 2009 In the last picture listed that whole profile is sealed. The other part that show in the top couple of pictures is the ported side. Hope that clarifies. So is it a double chamber tri tuned 4th order? If I understand correctly, you have a small sealed chamber behind the woofers, but its only sealed from the outside. it is ported to another sealed chamber. If thats correct in my assumption, the ports between the chambers act like a one way valve and open up at a certain frequency range. So in a certain range, the enclosure will act like it has a small sealed chamber and be tuned accordingly, then at certain frequencies when the ports "open up", the sealed chambers will couple and the entire enclosure will have a different tuning due to the seemingly larger sealed chamber. I'm just guessing thats what your doing based on what we see so far. I wanna see more to see where you are headed. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
bcpballer64 Posted December 27, 2009 Author Report Posted December 27, 2009 So is it a double chamber tri tuned 4th order?If I understand correctly, you have a small sealed chamber behind the woofers, but its only sealed from the outside. it is ported to another sealed chamber. If thats correct in my assumption, the ports between the chambers act like a one way valve and open up at a certain frequency range. So in a certain range, the enclosure will act like it has a small sealed chamber and be tuned accordingly, then at certain frequencies when the ports "open up", the sealed chambers will couple and the entire enclosure will have a different tuning due to the seemingly larger sealed chamber. I'm just guessing thats what your doing based on what we see so far. I wanna see more to see where you are headed. Yes and no. when you look at the last picture the rectangle portion the subs are going to be facing up right there then between the square section and the triangular section there is a one inch gap as wide as the chamber. That gap is the "top of the pop bottle" so to say the volume of the chamber is always there but the pressure will be have to get high enough for there to be a pressure in that gap because at low volume and little displacement there wont be that much air moving back and forth, so yes as designed the louder the volume (or technically more pressure) the greater the effect. That profile in the last picture is the "back side" of the woofer the cone side is a ported enclosure which makes it a bandpass enclosure if you look in the first picture you can kind of see what i mean. I think. "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
bcpballer64 Posted December 29, 2009 Author Report Posted December 29, 2009 Im going to post some new pics here in a few. "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
kirill007 Posted December 31, 2009 Report Posted December 31, 2009 Where are the pics? Thinking is the root of all problems... You ALWAYS get what you pay for.
bcpballer64 Posted January 2, 2010 Author Report Posted January 2, 2010 Wow sorry it took so long to post pics family kinda up and left on a surprise trip. Anyway here are the pics. I know the material on the outside looks like crap but its all i had to work with. So nail me to the cross. Should be done late tomorrow hope to be bumping again soon . "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
bcpballer64 Posted January 3, 2010 Author Report Posted January 3, 2010 When i finish this install i will be changin the back battery and putting a kill switch in the cabin in case thee popo be comin. Does this look right? I have the subs and stuff all wired i just added it for looks. "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
keepinitloud Posted January 3, 2010 Report Posted January 3, 2010 interesting......how about some vids of the box playing 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
bcpballer64 Posted January 3, 2010 Author Report Posted January 3, 2010 interesting......how about some vids of the box playing i will once i get it istalled i have a little bit of carpeting to finish tonight or tomorrow and get it in my car and hooked up. i should have vids tonight or tomorrow. i dont have the led's yet and wont until i get my tax return then it will be lit on the inside and much more BA looking i am also going to put some leds in the car itself and im going to install the switches when i do that stuff. vids soon tho tonight or tomorrow "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
