Burb Build 4 18" Re X X X 150++ Daily Driver!
real hot and fast like after just a minuet of music....weirdest thing I have ever seen....getting just under 14 volts at the amps and putting out over 2k of wattage not clipping....I.D.K.................
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Yeah that is kinda nuts..Have you let them play, takin them past the point where they get real hot?? Do they start smokin?? That is the weirdest thing...
Smoking??? Blew the F up is more like it 2 to be exact to this day......kinda disapointing
Scientia est Vox
So you think you have to much port area?? You outta just go traditional and put a front on the box with either one big port or 4 seperates.. That box design is just so radical..I would at least try it with the front on it, then if it still does that then change those damn things out and put some FI BTL's in there...
well tonight will be the last voltage electrical test session for these then its on to reconstruction.......I'm tired of messing with them for real.............
Scientia est Vox
Im no pro, and I could be way off, but it looks like alot of port area to me, thus allowing the sub to unload and get hot quicker because of the amount of work its doing.
I see what your saying but every calculator and program I used said I needed 4-500 sq" of port tonight I will try blocking some off and seeing what happens...
Thanx for the input guys!
Scientia est Vox
