Shyne151 Posted December 31, 2009 Report Posted December 31, 2009 Had a Volvo S60 come in today for a remote start... hooking up the starter took no time at all and I ran into no problems... Putting the transponder ring in is where I started having problems... tried a 556u with just a regular ring and it wouldn't work... tried wiring the ring into the factory transponder wires... wouldn't work. I can get the vehicle to remote start fine if I actually put the key in the cylinder... but I can't get it to remote start at all if I hold it outside the cylinder. So finally here I am sitting at home and decided to jump on Mitchell and see if I could pull up the transponder diagram... So here it is: Am I reading it right... the Pin 1 in the antenna plug should be seeing 12volt while the key is in the ignition? So if that isn't seeing 12volt the car more than likely wont' start(I didn't have this diagram at work so I couldn't test it, hell it might be getting 12volts... idk i'm just going out on a limb here)? Gray and Blue are the wires that I used to wire in the 556u ring... Hopefully maybe ray or james has done one of these and key shine some light I know they do a hella lot more foreign cars than I do. So in a nutshell... it seems like the only time the transponder is activated is when the key is in the ignition... Damn Germans -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
Ray Posted December 31, 2009 Report Posted December 31, 2009 keysense. very common. just send your keysense wire from your alarm to it(make sure its set to + pol.) Dun sukka. And put my # in your phone. Just call me next time. And your welcome 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Shyne151 Posted December 31, 2009 Author Report Posted December 31, 2009 keysense.very common. just send your keysense wire from your alarm to it(make sure its set to + pol.) Dun sukka. And put my # in your phone. Just call me next time. And your welcome Yellow key sense wire has positive 12v going to it... it dings and everything when you goto remote start it. That's why I don't understand why I can't get it to remote start without the key in the ignition. -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
bassprodigy Posted December 31, 2009 Report Posted December 31, 2009 key sense can be a motherfucker on remote starts....... ive ran into a few of these installs myself...... 2003 Toyota Sequoia Pioneer 4100dvd Memphis PR6.5 3ways in all four doors Memphis PR 15s (4) Memphis PR 1.1000 (2) Memphis PR 4.50 (1) Optima Yellowtop (2) Viper 5901 8000k H.I.D. kit 15% tint (2layers)
Ray Posted December 31, 2009 Report Posted December 31, 2009 Yellow key sense wire has positive 12v going to it... it dings and everything when you goto remote start it. That's why I don't understand why I can't get it to remote start without the key in the ignition. call computech support. maybe they can shed some light. I always cut the factory ring and use it. On those euro cars anyway. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Ray Posted December 31, 2009 Report Posted December 31, 2009 i found this.. VOLVO SECURE TAKE-OVER NOTE: These vehicles are covered by a secure takeover feature for improved anti-theft protection. Failure to follow the instructions below will result in immediate vehicle engine shutdown. ◊ All doors must be closed before attempting to remote start the vehicle. ◊ Upon remote start, the customer will have to press unlock on either the after-market remote or the OEM fob. ◊ Once the doors are unlocked, the user has a 45 sec time frame to open a door and press the brake pedal. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Ray Posted December 31, 2009 Report Posted December 31, 2009 so what is it doing when it tries to start? is ign lighting up? make sure all the accy's are lighting up??? Im guessing it's just not going into crank. gotta be something with the doors open, or the keysense is weird. I'd triple check that keysense, and your imm. ring. voltage is staying good? no batt charger on it right?? call my cell if you want. 559-355-0289 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Shyne151 Posted December 31, 2009 Author Report Posted December 31, 2009 so what is it doing when it tries to start?is ign lighting up? make sure all the accy's are lighting up??? Im guessing it's just not going into crank. gotta be something with the doors open, or the keysense is weird. I'd triple check that keysense, and your imm. ring. voltage is staying good? no batt charger on it right?? call my cell if you want. 559-355-0289 He's bringing it back saturday morning... All accessories and ignition are powering up... basically it just wouldn't crank unless the key was in the ignition. I'll have to read up on the volvo secure key take-over thing... I talked to both directed canada and usa... turd from USA was no help. The guy from canada atleast said he would call me back monday when his volvo engineer was in. Bah I haven't had a remote start I couldn't get to work in probably five years... shit pisses me off because I just keep thinking about it! I might give you a call saturday... thanks for the help ray! -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
huh?do-what? Posted January 27, 2010 Report Posted January 27, 2010 He's bringing it back saturday morning... All accessories and ignition are powering up... basically it just wouldn't crank unless the key was in the ignition. I'll have to read up on the volvo secure key take-over thing... I talked to both directed canada and usa... turd from USA was no help. The guy from canada atleast said he would call me back monday when his volvo engineer was in.Bah I haven't had a remote start I couldn't get to work in probably five years... shit pisses me off because I just keep thinking about it! I might give you a call saturday... thanks for the help ray! in five years? I must be retarded! I get one a month that kicks my ass. God damn its hot today. My balls are stuck to my leg.
Mtgrooves Posted January 27, 2010 Report Posted January 27, 2010 I've been doing this for 15 years and remote start season always bruises my ribs! I haven't done the car that you talking about but it sounds like ray is on the right track The Shoe Maker without shoes!
