So its been forever since i have posted up any of my builds. i havent had internet for awhile and havebeen workin all night. But hers the latest one."
The vehicle is an 06 Jeep Grand Cherokee.
Sub: 15" Fi BTL
Amp: Rockford Fosgate t2500bd
Batterys : CD tech 76ah
Wire: Knu Kolossus Fleks 1/0
So my first thoguht was that i had to make this build really classy and look integrated with the car. the customer is 16 years old and his dad was really worried about me destroying the car in the process lol. So i had to make the spare tire bolt accessable, and be able to take everything out and out it back stock. i couldnt take up the entire back either. I also had to use the stock nav head unit :(...so along with the LOC i had to add a line driver lol.
So first step is makin the box as small as possible. i ended up around 4ft^3 @33hz.
The port had to be raised up becasue of the false floor. i also covered the inside of the port in Brushed aluminum ALUPANEL, an 1/8" aluminum/abs composite panel.
next comes the false floor which fit nicely in the area where the old floor was. the front of the box is also partly covered in Aluminum for the parts that will be exposed through the front plate.
after a lonf night of thinkin how i was going to do the floor, 9515rob gace me the idea of curving it with the factory panel. so this is the template piece that will be used to create a raised edge with bondo that the wood grain inserts will sit flush in.
with the floor cut out
The body filler done. the template has to be sanded down on all edges so it will fit with the vinyl on there.
A few pics of the wood grain insert and vinyl. its kinda hard to see the raised edge in these pictures.
NOVEMBER 2008 SYSTEM OF THE MONTH!
ORIGINAL YUKON BUILD!
TEAM DTF
TEAM Rival Mobile Electronics
TEAM Xs Power
94 yukon
12 Rival C15s
50+ Boston mids and highs
15 Xs power D2400
600+ ft of 1/0
10+ gallons of resin
99 Silverado.
4 15" Treo SSX
Stetsom 14k2d
5 CD tech batteries
155+ daily
Team DTF
"did you just drive past my house in your stupidly loud car. if it was you, you knocked a vase off my fire place."
next is the front panel. becasue of the curves of the quarter panels i had to get complicated to get it perfect. i should have taken pics of how i did this but its pretty common. i rough cut the edges of the board and then taped off the side quarter panels. then i took Fiberglass reinforced filler and forced it into the gaps between the board and the panel. after it dried i took it out and sanded off the excess with abelt sander. it turned out pretty damn good.
then i took it and did the same bondo technique with the port vents.
here it is with some vinyl
the front panel is raised off of the box 1/4" so that LEDS can show through the gap.
The rest of the build i had to rush to get it out of the garage so i didnt take any pics. but hers some finished pics.
TEAM DTF
TEAM Xs Power
94 yukon
12 Rival C15s
15 Xs power D2400
600+ ft of 1/0
99 Silverado.
4 15" Treo SSX
Stetsom 14k2d
5 CD tech batteries
155+ daily
Team DTF
The white diamonds on top are woodgraid abs rings with white plexi so that the blue leds with give off more of a glow. Under that is just white formica so that the light will relect better. the left one will have a rockford logo and right a FI. the middle one has my KG logo that is painted from the back. i had reverse decals made for that reason lol.
Il post better pics up when i get my other camera and he comes back over int eh day time. it was a pretty damn clean install lol. the batterys wer hidden behind the seat, i forgot to mention that
TEAM DTF
TEAM Xs Power
94 yukon
12 Rival C15s
15 Xs power D2400
600+ ft of 1/0
99 Silverado.
4 15" Treo SSX
Stetsom 14k2d
5 CD tech batteries
155+ daily
Team DTF
A+
DC.jpgDC POWER
looks nice :good:
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
Freakin clean man!!! I still wanna see pics of how u hid the battery
"FRIENDS MAY COME AND GO BUT 200 POUNDS WILL ALWAYS BE 200 POUNDS."
-System in progress- SYSTEM SHOULD BE DONE BY THIS MONDAY!!!!!!
15.2 Orion HCCA
4 Cubic ft tuned to low 30's
MB Quart DSC1500.1D
Kinetik HC1800
Kinetik HC800
50ft of KnuKonceptz 1/0 gauge
10ft Kicker 4 gauge
"LET THE PAIN COME OVER YOU, BUT NEVER LET THE PAIN OVERCOME YOU."
il take one when he comes back. i notched out the back of the box a lil bit and the slant of the seat made it a perfect fit
TEAM DTF
TEAM Xs Power
94 yukon
12 Rival C15s
15 Xs power D2400
600+ ft of 1/0
99 Silverado.
4 15" Treo SSX
Stetsom 14k2d
5 CD tech batteries
155+ daily
Team DTF
Fricken Sweet Work man!!!!
I'd like to see how you did the battery too...
NRA - Patron Lifetime Member
'"the right of the people to keep andand bear arms shall not be infringed"
