Long road to 6 older style btl's
Also have you ever even heard a vehicle that does mid 50's on music? Cause if not you'll be way more than happy with the 4 18's you have right now. Cause Im not to sure you realize how loud that already can be.
Yep, you're not the only one who found it a little comical.
What is so comical? I think it is smart to do it right the first time and learn as it is being built. IMO
I could do it and mess something up and repeat it to sat "I did it myself" but that just seem like pride. I have pride but I think in that case pride would be my down fall. I am learning and helping in my build, but I just won't be the main person behind it.
Thought you knew? He should be TheBEastJr instead.
Ha ha ha ha lol
Thats why I will be doing 4 right now. I feel you on this
Honestly I would just stop there man. Trust me it will get loud enough. And save you a ton of money, cause your going to probably ending up spending over 10k in electircal alone, for 3 14k's.
what's going on with the suspension of your ride also?
Vehicle: 2001 Dodge Dakota
Headunit: Alpine IVA-D310
Sub: 2005 RE Audio XXX 15"
Sub Amp: Orion 2500D
Frontstage: Diamond Audio Hex's
Frontstage Amp: Sundown Audio SAX-100.4D
Wiring: Kicker Hyperflex 1/0
Alternator: Mechman 250 Amp
Battery: Powermaster D2700
Deadener: 100 Square Feet Raamat BXT II
@ OBI :sorry: :sorry: :cray: :cray: :cray: :cray: Honestly I have been thinking about that, and if that is the case with only one or 2 decent sized amps and nothing too flashy I may just have one of my favorite installers just help me do the build and keep upgrading until it looks and feels how I want. I don't expect perfection after all I am going for spl with a hint of sq. ( I know)
I am upgrading to after market suspensions but so far it is 4wd so it can still haul on stock suspension for a little while.
I actually am thinking about reconsidering but how will 6 18" subs at d2 each run on 3 amps at one ohm? so far I am stomped
3 D2s can be run @ 1.3 ohms, so it won't be too far off.. I personally would have run SD 12ks instead of Stetsom 14kds, but that's just me.
So u think that a shop like Custom Edge is gonna just let u sit in the install bay for multiple months while they are building it?? They are gonna have you drop off the truck, give you an estimated time table and pick it up many weeks later. This isn't really something that can be done in a couple days or even a week at a shop like that since they will have other customer's vehicles in their also.
If I were you I'd just end it with 4 18s + the Stetsom amp.. If it's built correctly then you should be pretty damn loud and more than happy with the results.
Pioneer AVIC-N2
See man. Im telling you, you'll be more than happy with that. Trust me.
Ok I think I will do that...............for now. Honestlyl I kinda made that decision when I made this thread, but I was being subborn with myself. lol Thanks for those that had informative information it was needed. Again thanks.
