amp cutting out
bigarsenal
with 160 amps and depening on your total system draw you should good ad the extra battery it wont hurt since you have more than a 90 amp alt
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
well i have two T2d4s, they both are wired at 2 ohm and bridged together for 1 ohm. my hifonics 1500d is 1 ohm stable. my gains are up a tad bit, let's say from min - max, they are at min and up a hair. all the wiring is double checked and i still don't know the problem. it hasn't done it lately but i'd like to find out why. i have my amp grounded through my 2 capacitors. maybe that might be the problem and then i have a 13 inch long ground running from my caps to a bolt located under my third row seat ........ that might be a problem too. i'm going to shorten up everything and give my amp it's own ground and see how that works for me.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
to get it back on i have to cut my CD player off(of course the amps, caps and all goes off) and when i cut it back on the bass is back in untill i get it up loud again and the bass is slammin like crazy. it only does it every now and then, like really not days or on some songs i have that hit really really hard. i still think my grounds might have something to do with it........ i've heard you should ground an amp with capacitors. so i'll see in the future.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i just checked it out im not losing any power. well i have a componet set in the front and one of my six in a half is blown is this causing my amp to cutt out :R :R >:( >:(
Subs- 2AA Arsenal 15sAmps- Orion2500d/MemphisDoors- Infinity kapa/AA polymids(soon)Deck- Pioneer PrimerBox- 3.5 per chamber!!!!!!!!/28hzElectrical- two optima red tops/160alt(big 3 soon)OHIO BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
that's what i think my problem is. i'm going to ground my amp separately and no on the caps. then shorten up my ground on my caps from 13 inches to 6 inches. should make a good difference.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
does anybody know my question >:(
  • Who's Online   0 Members, 0 Anonymous, 582 Guests (See full list)
