MTX J30 Posted January 5, 2010 Report Posted January 5, 2010 what does it do and is it worth buying it? Once or twice I have missed having a back seat / rear hatch, but all in all people love to see a walled vehcile. It just screams "i'm not fucking around with my setup, im loud"
3gAccord Posted January 5, 2010 Report Posted January 5, 2010 It's worth it. My latest project; 87 Accord Hatchback!... Only got my 6 1/2's in it right now... I'm working on shining my engine to show quality right now, then I'll put it in. System will come around the 1st.
Loudcav Posted January 5, 2010 Report Posted January 5, 2010 its worth it if you know what your doing but you cant really get away with buying a cheap EQ you really do get what you paid for
MTX J30 Posted January 5, 2010 Author Report Posted January 5, 2010 its worth it if you know what your doing but you cant really get away with buying a cheap EQ you really do get what you paid for i dont undertsand how it works or exactly what it does. Once or twice I have missed having a back seat / rear hatch, but all in all people love to see a walled vehcile. It just screams "i'm not fucking around with my setup, im loud"
HHR Ed Posted January 5, 2010 Report Posted January 5, 2010 an EQ merely gives you adjustability. It allows you to turn down or up specific frequencies. An example is an EQ that has adjustments as 80 hz, 1000 hz, 10,000hz. If you have too much sound around 1000hz, you can turn that adjustment down. Its like an advanced bass and treble adjustment. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
tacomabanga1986 Posted January 5, 2010 Report Posted January 5, 2010 are u talkin bout an add on eq or one that comes in ur headunit? an eq like this this type eq takes the full range signal comein from ur deck givin if it only has a bass/mid/high adjustment n gives u more of a tuneing curve n lets u cut n boost any givein freq u need to to help dial in the sound u want n some give u a sub out wit a gain knob so u can do it steve meade style or adjust the xover slope on the sub out so it will play a lil bit more diff and some ppl use em cause they boost preamp voltage to help get a better signal to amps also then we get into electronic xovers like this these type of 3 way xovers give u the ability to run active if u wanted to or help set a freq cut off on certian channels so u can get a cleaner sound if ur amp doesnt have a good built in xover i got a xover kinda like this one but newer it lets u change the freq range of the front channel n lets u boost it 10times to change the freq's from around 500htz to 5khtz so u can run tweets off front n lets u run the rear channels as fullrange or bandpass n gives u a freq range of cutoff points so it just plays mids n what knot kinda like how an xover would work on a comp set hope this helps here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
Soulman07 Posted January 5, 2010 Report Posted January 5, 2010 It does tons of stuff... Depending on what you want to use them for, is really why you would would purchase a certain one. So we can't state any specifics really, it's going to be a pretty vague response either way. 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex
Kevin631 Posted January 7, 2010 Report Posted January 7, 2010 How would you wire one of these (sorry Im a noob, Learning quick though)
