Need help with subwoofer.
My sub in my car no longer works, so I need a replacement. I was thinking of either HFI12D4 12" DVC 4 Ω 600 W MAXX 300 W RMS or HFI12S4 12" SVC 4 Ω 600 W MAXX 300 W RMS or is there anyone out there that has a 12" subwoofer that I can buy off them. The only reason why I am looking at these subs, cause right now I am on limitied budget and have alot of bills, I need to pay off. Before I forget, here is the specs on the amp i have
Pioneer GM-5100T 2 Channel Amplifier (760 Watts)
* CEA-2006 Compliant Amplifier Power Standard:125 Watts x 2 @ 4 ohms <= 1% THD+N
* 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
* 75 dBA Signal-to-Noise Ratio
* Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
* 2 Channels
* Continuous Power @ 4 Ohm: 125W x 2
* Continuous Power @ 2 Ohm: 190W x 2
* Continuous Power Bridged @ 4 Ohm: 380W x 1
* Frequency Response: 10Hz-50kHz
* THD (1kHz, 4 Ohm): <0.015%
* Signal to Noise Ratio: >95dB
* Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
* PWM Regulated MOSFET Power Supply
* Balanced Isolator Input Circuit
* Oversized Screw-Type Power/Ground Terminals
* 2 Channel RCA Inputs
* Speaker Level Input
* Screw-Type Speaker Terminals
* Hi-Volt Input Level Control (200mV-6.5V)
* Bass Boost (50Hz, 0/6/12dB)
* Selectable LPF (80Hz, -12dB/Oct.)
Pushing it to the limits. Want more power.
Well right now I have $50 in my paypal account, I can possibly save up more from my deliveries the next couple days.
Looks like my search might be over, my friends dad might be hooking me up with either (from his car stereo friend) PHOENIX GOLD V12D
12" DUAL Voice Coil 600W RYVAL Series SUBWOOFER or Power Acoustik BL-12 12" DUAL 4 OHM 300W Power Handling Woofer in exchange for doing some work on his truck.
I got a sub, my friend got me one from walmart and it is off brand sub. Not the best, but will do until I get my sub repaired (found out one of the tinsels broke off from the connector).
  • Who's Online   0 Members, 0 Anonymous, 766 Guests (See full list)
