What do you all think is the best style of box for ford explorers years 2002-2005?
Right now I have a decent box, sub up port back (in the bottom middle of the box). It sounds nice, but I think that it could be a ton louder with a better box style and building it better.
It was my first build box, im ready to try again. I'm thinkin birch, but might just use mdf.
Ive heard sub up port back to the drivers side/pass side, and sub up port up. Don't know which one I want to do.
It is for a 18" btl btw, not asking for designs, just styles that should work well.
Thanks
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
sub up, port back usually yields the highest SPL in explorers
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
yeah but port back at the side ? Driver or passenger? I feel like with the port on the bottom its not moving as much air as it should, and is getting constricted
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
It'll take some experimentation on your part.
I have seen the highest SPL with port in the middle on the bottom
Ed Lester
ShowtimeSPL Host
My old Build Log
Well, my explorer is an 01, but it's a sport, the 2dr style, not the 4dr style. I tested sub up, port back (driver side), sub up, port forward (passenger side), and sub forward, port up (driver side). The one that worked best for me and was loudest to my ears, was the sub forward port up. All the ways were tested in same box, just moving it around. But the sub up port back, or sub up port forward might put up a higher number on the TL than sub forward and port up (going to test it all when I get my license back and it's not restricted anymore). All I can tell you to do is just test around and see what sounds best to you.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
thanks guys for the help, maybe ill just wait to get this on a tl before i rebuild it, and then make it better
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
If possible, try experimenting with your current box before you build another one. You are running sub up/ port back right now, but what happens when you turn that same box around so that the port faces front? Left side? Right Side?
In Explorers, I try to keep all the output as close to the back hatch as possible. Hasn't failed me yet.... :hairtrick:
Really I thought farther away would be better! Maybe I'll try that out. ill try turning it around too see how that sounds.
thanks
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
My box in my 2003 Mercury Mountaineer (Ford Explorer) is 8 inches from the rear hatch. I run 4 ports firing towards hatch, there is two on the driver side and two on the passenger side
how do you like that? is there much port noise? how well does it compare to other ported boxes in your suv?
1998 jeep grand cherokee
future teardown and rebuild:
2-15.4 orion hcca's
sub amp undecided
2 sets of components
1-concept amp (mids/highs)
undecided h.o. alt
2-yellow tops
