well i was supposed to be running 2 dc audio xl 12s at this weekends show but it looks like i wont have my other motor by then
so i need to decided what i want to run quick
here is all the stuff i have that i can put in
2) 10inch incriminator audio 187s each is a dual 3.5 ohm
1) 12inch dc audio xl with all lvl 5 soft parts dual 1.4 ohm
2) 15inch dc audio lvl 3s each sub is a dual 4 ohm
amps i have
1 sundown sae 1000
1 sundown saz 2000
2 sundown saz 3000
i am will to run what ever i just need help making a decision quick i am willing to run what ever i just need to put out as high of numbers as possible even if the woofer has to take a beating
the 2 15's lvl 3 and the 2 sundown 3000's at 2 ohms would be a good burb
music your gonna have to VERY careful
Edited by Team Bassick (ALPINE)
another thing i would like to run my amps lower ohm load than higher since i am competing in USACi the class i run in is based off of the amps 4 ohm rating so the more power i can get out of an amp the better
the kicker lol the two 15 lvl 3 on a 3000 at 1ohm for burpin
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
if you are going stricktly for burps then I would run the DC 12 and the two SAZ 3000's strapp them at .7 ohms each amp will see a 0.35 load that should be the most power you are going to get out of any of the setups you could do? but becareful!! you could let the smoke out!! good luck!
