no power at the end of the wire? wtf? help
idk im like really confused on this install I did? I get power after the fuse but at the amp I get no power. I have changed the fuses and fuse holders and idk what the problem is... DMM reads 86 micro-volts at the end of the wire. Please explain im really confused
What?
It has to do something with the fuse. What do you mean there's power coming after the fuse, but then you say there's not?
I hope you aren't fooling around with the power wire with the negative post on the battery still connected.
Vehicle: 2001 Dodge Dakota
Headunit: Alpine IVA-D310
Sub: 2005 RE Audio XXX 15"
Sub Amp: Orion 2500D
Frontstage: Diamond Audio Hex's
Frontstage Amp: Sundown Audio SAX-100.4D
Wiring: Kicker Hyperflex 1/0
Alternator: Mechman 250 Amp
Battery: Powermaster D2700
Deadener: 100 Square Feet Raamat BXT II
No I hooked the DMM after the fuse and I get power there, but at the end of the wire by the amp it reads 86 micro volts(varies)
amp works just fine I hooked it up off a different battery.
and if it grounded out wouldn't the fuse pop? but I also checked if it had and everything looked fine.... its so weird
any kinks/pinches in the wire
BIG STICK
2005 Chevy Malibu 3.5L v6 (Impound Status)
(New) Hifonics Brutus BXI 2010D - Courtesy of Maxxonics
(2) Kenwood KAC-8402 Amps for mids & Highs (ok for now..)
Pioneer DEH-P2900MP Head Unit
(4) 6.5" Soundstream Tarantula's
(2) 5.2" Soundstream Tarantula's
(6) 1" Tweeters
(2) Fi BL 15"
BX15 Soundstream Bass Booster
0g Streetwire
if you didnt had a ground, you would of blew fuses in amp
I checked and replaced those too but there is no power at the end of the wire to even blow the fuses(it was grounded though).
I checked to see if it was pinched or anything but it was all fine
take your car apart and find the source of the problem
power is not something you wanna mess with
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
