when my bass hits my lights dim dash lights and interior lights not sure about head or rear lights. any ideas how to fix it?
2 15in Kicker comp (new sub)
1 1500d hfi Hifonics amp
2single 15 boxs 3.5 cubes sealed
JVC KD-R200 headunit
Stock battery and alternator
lanzar 440watt 3way coaxials
4awg JL Audio power
4awg JL Audio ground
JL Audio RCAs
bigger or 2nd battery
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Your best bet would be to stay away from the cap if your already having electrical issues. Start with the Big 3. here That should at least help. Depending on the setup you may need a bigger, or multiple alts, as well as more batteries. Like Tyler said, full specs on your system would help more.
well im not trying to spend big bucks on a new alty considering this is my first car and wont have it long. i was thinking about a new battery but getting a new battery may require a new alty same with getting a second bat
idk what amperage my alty is but its stock on a 99 ford taurus se 3.0l
i have 2g jl power wire but my amp has small connection terminals so not all of the dookie ass wire is under the screw
that have something to do with it?
Big3 may be a pretty good ideaonce i get money
Edited by maxmelber
4awg JL Audio power
JL Audio RCAs
i was running 2 rear batts of a stock 90A alt you should be fine do the "big 3" it will help cheak your grounds make sure there good try to get as much wire into the terminal as you can and make sure your gains are set right
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
I ran three large batteries on a stock 105amp alt with no problems for 6months...
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
why is my amp turing on (green led) then shutting off (red) then kicks on for a second. wtf wtf help b4 i cry :shot:
4awg JL Audio power
JL Audio RCAs
Your amps going into protect from the voltage drop you have. With the upgrades your looking at i would get 2 batteries with nothing less than 100ah to start and maybe add another or so later depending on dropping voltage.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   1 Member, 0 Anonymous, 1829 Guests (See full list)
