forget soldering, forget crimping, here it is...pics
greatest amount of surface area contact comes from crimpin
solder is not very conductive, so solder alone i would never do
a set screw is nice but the pressure is only below the screw, not nearly 360 degrees like a crimp
nothing beats copper to copper, nothing
ill bring this out,
why do they use it in amplifiers then?
ill bring this out,
because solder is the easiest way to make an electrical connection between two solid items.
solder is usually below 50% conductivity, compared to copper.
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
THose look very nice and it copper too. Where did you get those?
Seems like a good idea, a lot of work at first but since they are reusable it's effective.
1993 Jeep Cherokee Sport
Kenwood 5.25" Mids
Alpine SPS-500 5.25" Mids
4 awg Rockford Fosgate wiring kit
Rockford Fosgate P312D2
Phoenix Gold Tantrum 1200.1
Phoenix Gold Tantrum 600.4
Pioneer DEH-3100UB HU
ill bring this out,
Because you can't crimp 1000 connections with 1 pass of a special machine ;)
Look up 'wave soldering' and 'reflow soldering' and you'll see why they do it.
If you use enough solder the size of the connection usually far exceeds the package limit of the part it's actually connecting ;)
10.x volts fo' life!
I get them from Ace Hardware in the Welding section, you could probably find em at Home Depot, or another store that carrys welding supplys.
¿ǝɯɐƃ ǝɥʇ
