forget soldering, forget crimping, here it is...pics
I've got some stinger ones for my 4 gauge to my 2 channel
works nice and you can reuse them :)
just make sure to get them sons of bitches tight!
Wouldnt be thehoe92 without teh purple
I always thought how it would work if you were to take those kinds of lugs, and fill the bottom half with solder, heat up the lug till the solder is pooled in the bottom then stick the wire in, would it work?
Anybody got any feedback on that?
Also to the OP good Idea, they have those already but they are real expensive, what you have is a cost effective solution.
¿ǝɯɐƃ ǝɥʇ
Ive seen guys at work pool the solder and it works for them but it was done in tight spots where they couldnt crimp the wire ,ive always drilled a hole in the front and fill with solder while heating just to get enough in the wire strands
