My system is what is in my sig.
My box is 3.1 cubes tuned to 35 hz with my own aeros. Due to the depth of my box I had to use PVC elbows to reach the length I needed for the 35 hz tune.
I was playing around with WinISD the other night and I figured out that if I remove the elbows my tune moves up to around 48 hz.
Would burping with the 48 hz tune do better for me than burping with the 35 hz tune? Im not sure what freq I would burp for either since I assume my peak freq has chaged since I was last metered since I changed boxes and subs.
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
not in a sunfire since your res frequency would be around 47 hz.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Ok thanks. I couldnt find a ballpark on a res freq for my car.
Alpine CDA-9886
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
should be 47-49 or somehwere in there you'll need to put it on a meter for sure. but I know thats where my cav was.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Last time I peaked at 42hz which I know probably is irrelevant since my gear has changed but we'll see when I get metered again
Alpine CDA-9886
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
  • 1 month later...
i would say just test it, my peak in my yukon was 53-54hz and i tuned to 56 and it still got a little louder at same peak frequency, so now i am tuning to 53hz.. so even if it isn't louder it will give you an idea of what tuning range would be best.
1996 GMC YUKON 2dr
Eclipse cd5000
six- Soundstream T5 12's in 13^ft tuned to 30.4hz,43.04hz, and 53.53hz soundoff
149.8 on TL in kick,150.0 SEALED in kick 147.8 SB4
3 RF T5002's--------------going to 3 Soundstream DTR1.3400D's
two- Stinger sp1000's----going to two- BATCAP 4000's
2 140 amp alternators---going to 300amp Ohio Generator
2 runs 1/0ga, big 3-------going to 4 runs 1/0g + and 3 runs 1/0g -
MB Quart QSD 6.5's in doors---soon to come
my build log HERE!!!! check it out!
  • Who's Online   0 Members, 0 Anonymous, 2940 Guests (See full list)
