Are you talking about just strapping 2 amps together??
Pioneer AVIC-N2
Can anybody explain this to me and how you would even wire two amps together? Ive been looking on google for almost and hour and ive learned nothing about it
try googling daisy chain amps.
some amps can do it some cant....
its a matter of the amp being daisy chainable or not.
hope that helps/ :hairtrick:
Edited by solosickness
Ride Stats:
2003 Ford focus Zx3 Hatch Walled System
X1 Solo X Kicker 18" "Enclosure: 7.8 cbft, Port Firing Into a Horn, On a 90*"
X1 Rockford Fosgate 40001bd "Now a Warhorse On my dresser"
x1 0g Big 3
x1 Kinetik 2400 "x4 Kinetik 2400's"
x1 Kinetik 1800
x2 Kinetik Special Edition True Silver Battery Terminals
x20 Gold Plated 0gauge 3/8 Ring Terminals
x25 Total ft: KnuKonceptz Kable 1/0 Silver Pearl* 2500+ Strands.
x15ft KnuKonceptz 8 Gauge.
-Soon Too Be Walled
Fav Quote:
They Dont Feal Me, But They Feal Me.
can somebody tell me how you even strap two amps together? Ive read like 5 different ways on google so i wanna get my facts right so I dont mess up an amp or something
Saving for the xxx18, xxx15000d batterys alts mids highs blah blah blah
The amps come with a data cable (looks like a phone cable). You connect the two amps with this cable via the data port. Then set the switch on one amp to "master" and the other amp to "slave". Then connect the NEG speaker terminals on each amp together. Then run from the POS speaker terminal on the "master" amp into the POS speaker terminal. Then run from the speaker NEG to the "slave" amp's POS speaker terminal.
Remember that your speaker load when you do this can be no lower than 2ohm.
TwinStack is just SoundStream's fancy name for strapping.
95% of monoblocks you join the negatives together, connect them with some type of sync cable (be it a simple RCA or a data cable or whatever) then connect + on one amp to sub + and - on the other amp to -.
Stetsoms are a bit different...
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 4996 Guests (See full list)
