soundstreamScion Posted January 19, 2010 Report Share Posted January 19, 2010 Can anybody explain this to me and how you would even wire two amps together? Ive been looking on google for almost and hour and ive learned nothing about it Quote Saving for the xxx18, xxx15000d batterys alts mids highs blah blah blah Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted January 19, 2010 Report Share Posted January 19, 2010 Are you talking about just strapping 2 amps together?? Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
solosickness Posted January 19, 2010 Report Share Posted January 19, 2010 (edited) Can anybody explain this to me and how you would even wire two amps together? Ive been looking on google for almost and hour and ive learned nothing about it try googling daisy chain amps. some amps can do it some cant.... its a matter of the amp being daisy chainable or not. hope that helps/ :hairtrick: Edited January 19, 2010 by solosickness Quote Ride Stats: 2003 Ford focus Zx3 Hatch Walled System X1 Solo X Kicker 18" "Enclosure: 7.8 cbft, Port Firing Into a Horn, On a 90*" X1 Rockford Fosgate 40001bd "Now a Warhorse On my dresser" x1 0g Big 3 x1 Kinetik 2400 "x4 Kinetik 2400's" x1 Kinetik 1800 x2 Kinetik Special Edition True Silver Battery Terminals x20 Gold Plated 0gauge 3/8 Ring Terminals x25 Total ft: KnuKonceptz Kable 1/0 Silver Pearl* 2500+ Strands. x15ft KnuKonceptz 8 Gauge. -Soon Too Be Walled Fav Quote: They Dont Feal Me, But They Feal Me. Link to comment Share on other sites More sharing options...
soundstreamScion Posted January 20, 2010 Author Report Share Posted January 20, 2010 ya strapping them together. The amp im looking at getting says it can do that so i was just trying to learn more about it Quote Saving for the xxx18, xxx15000d batterys alts mids highs blah blah blah Link to comment Share on other sites More sharing options...
soundstreamScion Posted January 20, 2010 Author Report Share Posted January 20, 2010 can somebody tell me how you even strap two amps together? Ive read like 5 different ways on google so i wanna get my facts right so I dont mess up an amp or something Quote Saving for the xxx18, xxx15000d batterys alts mids highs blah blah blah Link to comment Share on other sites More sharing options...
Andrew2944r Posted January 20, 2010 Report Share Posted January 20, 2010 What amps Quote Team Ampere Audio Link to comment Share on other sites More sharing options...
soundstreamScion Posted January 20, 2010 Author Report Share Posted January 20, 2010 soundstream pca-2000D Quote Saving for the xxx18, xxx15000d batterys alts mids highs blah blah blah Link to comment Share on other sites More sharing options...
Namosh Posted January 20, 2010 Report Share Posted January 20, 2010 The amps come with a data cable (looks like a phone cable). You connect the two amps with this cable via the data port. Then set the switch on one amp to "master" and the other amp to "slave". Then connect the NEG speaker terminals on each amp together. Then run from the POS speaker terminal on the "master" amp into the POS speaker terminal. Then run from the speaker NEG to the "slave" amp's POS speaker terminal. Remember that your speaker load when you do this can be no lower than 2ohm. Quote My Ram Quad Cab Blow-through Link to comment Share on other sites More sharing options...
Andrew2944r Posted January 20, 2010 Report Share Posted January 20, 2010 http://www.soundstream.com/manuals/2006/AM...0D%20SERIES.pdf Quote Team Ampere Audio Link to comment Share on other sites More sharing options...
Boon Posted January 20, 2010 Report Share Posted January 20, 2010 TwinStack is just SoundStream's fancy name for strapping. 95% of monoblocks you join the negatives together, connect them with some type of sync cable (be it a simple RCA or a data cable or whatever) then connect + on one amp to sub + and - on the other amp to -. Stetsoms are a bit different... Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
