I dont mean home built jobbers (probably a lot of threads for those already), but fixes to keep you going when you dont have time to do a proper fix at the moment!
Lets see your taped surrounds and etc :)
Here's my first entry: MA Audio HardKore 18. Spider glue sucks on these guys apparently. Ground off the end of a clip so it would fit next to the step near the magnet then pushed it on. Works great for now! Yes I epoxied it once before this.
edit - i'm going to use a right angle drill and a jig to make holes in the step that I can mount spider-retention plates (half-moon shaped stainless steel brackets that i'm going to make) instead of the crap glue.
Hammerdown... 1%
Just look at the original Frankenwoofer from Thorshammer's old LVL5 that he had beat to shit and back.
Pioneer AVIC-N2
I dont have pics but I have used nail polish and toilet paper to repair surrounds!
Starting From Scratch!!
nail polish and TP? wtf
not a true Franken woofer, but used a TC sounds motor, on a common frame, and I had to space the frame out 1" for coil to spider clearance
I usually try and do things right the first time, if I'am stuck with a loose glue joint, ripped surround, I say screw it, and re do it
toiletpaper.. reminds me of a guy that used the nick "chinese" on another forum who made basically toilet paper speakers.. they worked awesome lol!
Hammerdown... 1%
Hot glued the surrounds and colored them black and made new dust caps with cereal box's and tin foil.
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
  • Who's Online   0 Members, 0 Anonymous, 406 Guests (See full list)
