Hiss in my system, how do I get rid of it?
I've always had a slight hiss in my system, it was in my van and it's the same in my truck, just a little louder in my truck since there's 2 sets of components right there instead of one set. It attenuates with the headunit (9887) and I really don't know what to do about it. Any ideas? Ground RCA's? The headunit has a pretty good ground. The amp is grounded to the frame. Idk what to do, I've heard that the RF balanced line driver gets rid of ALL noise but I don't want to have to buy 3 of them, if I spend that much why not buy a 3sixty
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
  • 1 month later...
try grounding the rca's and getting new rca's for your amps...
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
Sounds like your amp gains are too high. In order to lower the noise floor of your system, you need to lower your gains. Sounds like your head unit doesn't have enough voltage to drive your amplifier.
Former USAC Director
MECP Certified First Class of 1997
First car in the world to register 150db from the dash and sealed, in the trunk of an escort, with 2 10 inch subs. In 1997:
http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=51;t=002600
Just my part in the modern development of SPL competition:)
Hissing is caused by one source not matching another source's voltage. If you're running an IPOD, does it hiss? On a CD does it hiss? Make sure to tune your amp on a CD, eliminate the hissing by adjusting the gains on the amp or any sources you have before the amp and after the deck.
The reason I say CD is because you can tune out the hiss on the ipod, put a CD in and still have a hiss. So, it's actually up to you. If you even run an IPOD or not, choose whichever music device you use the most and tune. Grounding the deck is just a cover up. With the exception of a few pioneer decks that have retarded integrated fuses, a properly installed quality headunit (4v+ output) with quality rcas ran correctly shouldn't have any motor noise at all. Doesn't sound like that is your problem, but grounding your deck won't get rid of your hiss.
- Jake
  • Who's Online   1 Member, 0 Anonymous, 1218 Guests (See full list)
