Marlo Stanfield Posted January 25, 2010 Report Posted January 25, 2010 What kind of power are you running?? 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
basslh Posted January 25, 2010 Report Posted January 25, 2010 Thanks for the input. how many db's you think your blazer hits? any idea? Your install looks good and very loud. i think close to 150 right now just need to get a bigger amp ***************************************** Head unit-Clarion Mids & Highs- Oxygen Audio 5.25's Highs Amp-ASA-600.4x Subs- 3 15in American Bass XFL's Sub Amps- American Bass VFL 500.1
kl0wn Posted January 25, 2010 Report Posted January 25, 2010 How much power are you planning on running? Because if you're going to run a certain amount of power to the single 15" BTL, and the exact same amount of power to the two 15" SSD's, the SSD's will get louder. Or you can go with the single 15" BTL with that certain amount of power, and then later on down the road when you get the $$ get another BTL, and double the power. All up to you, and what you plan on doing in the long run. 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
tlee2 Posted January 25, 2010 Report Posted January 25, 2010 btl are very loud but bl's get nasty too trust me. 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
slamming ranger! Posted January 25, 2010 Author Report Posted January 25, 2010 Right now i have a pioneer premier spl 2000d. It does 2000@1 ohm 1500@2 ohm 750@4 ohm had problems with the amp at 1 ohm, and no one knew why. anyone going to the spl comp in tucson,az???
KHARPS Posted January 26, 2010 Report Posted January 26, 2010 Are you going to have a topper and go through the back window or cut the back wall? The only way you're going to fit 15s in the bed of a ranger with a bed cover is if you make the cut all the way to the top of the bed and push the box through the cut. The bed isn't tall enough to have the subs sit inside the bottom and top boards and still be below the bed line. Here's a few pics of one of the 12'' setups I've had in a ranger blowthrough. The bed isn't tall enough to fit 15s this way, unless you found a hard bed cover that sits higher than the sides of the bed. The cut is about 32'' x 11''
slamming ranger! Posted January 26, 2010 Author Report Posted January 26, 2010 Are you going to have a topper and go through the back window or cut the back wall? The only way you're going to fit 15s in the bed of a ranger with a bed cover is if you make the cut all the way to the top of the bed and push the box through the cut. The bed isn't tall enough to have the subs sit inside the bottom and top boards and still be below the bed line. Here's a few pics of one of the 12'' setups I've had in a ranger blowthrough. The bed isn't tall enough to fit 15s this way, unless you found a hard bed cover that sits higher than the sides of the bed.The cut is about 32'' x 11'' thats excatly how my truck looks right now. same size cut and all. what dc 12's are those? and was it loud? and yeah i have a bed topper on there.
KHARPS Posted January 26, 2010 Report Posted January 26, 2010 thats excatly how my truck looks right now. same size cut and all.what dc 12's are those? and was it loud? and yeah i have a bed topper on there. It's hard getting a reg cab truck loud sealed up. They were LV4XLs in 4.6@32 on one Sundown 3k @ 1 ohm. I was doing 144.x on music sealed up around 38-43hz and 149.x in the kick with drivers door open on the same song. I now have 2-12'' DD 9512s on the Sundown 3k @ 0.5 ohm and did a 145.x sealed up on music and 150.2 in the kick. It's still peaking at about 40hz but my box is now 4.8@40hz.
