scfaust Posted January 26, 2010 Report Posted January 26, 2010 if i wanted to run 8 of these subs ( SI BM 10s (old models) and re-built them with several changes: 1) Slightly longer flat-wound coil (original was round wire) - USA made coils 2) Narrower / Taller Surround 3) Tied down tinsel leads Measured T/S Specs (coils in series): RE: 6.89 ohms Z: 8 ohms Fs: 27.2 Hz Qes: 0.56 Qms: 3.32 Qts: 0.48 Le: 2.8 mH Vas: 31.1 L BL: 16.2 NA Mms: 124 grams Power: 400 watts RMS 0.95 ft^3 SEALED BOX - F3 of 41 Hz 1.5 ft^3 ported tuned to 30 - 35 Hz for high output ) on a sundown 3000d final ohm load would be 1. how small can i make the box i want a small ported box maybe 7 cu ft ported at 35 if you could i would really like some help with the box thank you box for back of 95 explorer. also do you think they would sound better than my 2 15" dc level 4s http://i720.photobucket.com/albums/ww203/scfaust1/alphadamp.png
Lith Posted January 26, 2010 Report Posted January 26, 2010 if you wanna use the recommended box size for these, and you want to have it ported than you will need to have a bigger box than 7 cu ft... 8x1.5=12 idk if im right or wrong but thats what im saying.
Playa Named Joe Posted January 26, 2010 Report Posted January 26, 2010 I wouldn't go any smaller then 8 cubes on the box, I would probably make the box around 12 cubes if you have the room. 1994 Pontiac Grand Prix build
scfaust Posted January 27, 2010 Author Report Posted January 27, 2010 i thought the smaller the better power handleing http://i720.photobucket.com/albums/ww203/scfaust1/alphadamp.png
STEvil Posted January 27, 2010 Report Posted January 27, 2010 Could go small if you made a huge port like what you see in T-Line setups... and flare the end like a horn MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Torres Posted January 27, 2010 Report Posted January 27, 2010 i thought the smaller the better power handleing to an extent. you just cant make the box as small as you can or want. the subs still need air to breathe
cthedinger Posted January 27, 2010 Report Posted January 27, 2010 keep your DCs i am going to half to agree with the dwarf on this one jk mr. p If you have any questions PM me or Add me on Facebook CLICK ME! Shop at ct-sounds.com Subscribe to us on YouTube
