I heard from some that the Hifonics BXi 2610D & the AQ2200D have the same guts.
does anyone know if thats true ?
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
well I am very curious though . considering the american bass vfl150.1 and the hifonics bxi2200d shared the exact same internals.
vfl150.1 was rated 2900RMS
hifonics bxi 2200D was rated 2200RMS
but exact same boards
Edited by Tooshort064
95 Civic Coupe
Memphis 16-MCA3004
Cadence iA9,audioque 2200d and the bxi26xx all have the same board layout different components maybe but same layout.......
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
just because an amp shares a board, the internal components could be very different. there are little subtlties that you could never see from a pic on your screen (extremely unlikely) . out of all the amps listed aove, i would say the AB amp is the strongest and most reliable
1997 Astro
front:6 sets of T3 componets
Subs: 8 level 5 18"s (building 6th order BP)
Amps: 4 really big ones (totalling just shy of 50K)
Batts:
Alt: Ohio Generator
1996 Chevy Suburban
Sub amp: A fifth really big amp
Subwoofer: 2-15" DC Level 4 XL
Batts: C&D high rate--(x4)
Same fuckin amp.
EDIT:
Same MOSFETs, same drivers, same driver transistors, same layout, same transformers.
Different colour PCB. And the caps might be a little different, brand-wise.
EDITTT: Pretty sure you could even strap them.
Edited by Boon
10.x volts fo' life!
Same fuckin amp.
I know your a hard person to please and you know your shit. So if he says its the same fuckin amp then its the SAME FUCKIN AMP.
thanks boon
95 Civic Coupe
Memphis 16-MCA3004
Epic fail by me... it's identical to the BXI2607D. Not 2610d.
Double epic fail, minutely different input section. Like, one uses 2x TL072 and the other uses 1x TL074 to achieve the same thing (a TL074 is the dual version of a TL072)
Edited by Boon
