pioneer problem need some help!!!
I was hook my pioneer DEH-P600UB to the oem radio plug
Everything was on but when i turn volume up , i didn't hear anything.
Also i didn't use 4 channel for my speaker. Is that something wrong to my head unit ?
u need to hook the blue with white wire from your headunit to the blue wire in the harness that connects to the car
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
make sure you have all the wires conencted, if its newer car with an amp..the the deck will turn on but not the oe amp. Atleast thats wut happened to me in my jimmy, i hooked everything up, so i thought and it turned on but no sound went back i figured out i missed a wire, after that BAM the sound came on :-) hope this helps
well every wire are all connect it and still northing sound,
also is that blue wire hook to white wire on oem plug or head unit plug.
well should reconect everything and connect it again ?
Well all wire's are connected,And still no sound.
also does the blue wire connect to the white wire on the oem plug or the headunit harness?
or should I disconnect and reconnect all wire's.
your sentences make no sense at all.
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
This isn't English class, but since you made it that way I figured I would go and correct you also.
Well all wires are connected, and there's still no sound.
Also, does the blue wire connect to the white wire on the OEM plug or the head unit harness?
Or should I disconnect and reconnect all wires?
Eclipse cd7000
pwned.
:censored: damn you s@cker
what car is this?
  • Who's Online   0 Members, 0 Anonymous, 405 Guests (See full list)
