Miakehl Posted February 5, 2010 Report Posted February 5, 2010 I've been having a problem with my amp cutting out if the bass boost gets turned up a smidgen too much, only problem is that level is like 40%. I've already check my ohms. its exactly 2.0 at the amp. Voltage won't drop below 13.3 at full tilt. Removed the LOC and swapped it for the line-level to RCA adapter that came with the amp. What do? Vid 1: Some Bass Mekanik Better Video: DJ Billy E [HOONIGAN]* '01 Ford F-250 LWBJVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4
kirill007 Posted February 5, 2010 Report Posted February 5, 2010 How did you set the gain? I hope with a scope or a DMM. Because if you're doing it by ear and if you don't have "trained" ears you could be clipping hard. You shouldn't us bassboost as it clips the bass freqeuncy around 45hz and also creates a big peak. The more clipping you have, the more heat, but doesn't always means louder. So just put you're bassboost on 0 and bass on you're HU also on 0. EDIT: i hear the clipping, so just set you're gains with a dmm.(their is a thread about it in the amplifier section i think) setting you're gains Put you're bassboost at 0, and set you're gains. Thinking is the root of all problems... You ALWAYS get what you pay for.
HHR Ed Posted February 5, 2010 Report Posted February 5, 2010 I never use bass boost, it adds clipping to the signal and sends amps into protect. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
Guest IntoxicatedFailures Posted February 5, 2010 Report Posted February 5, 2010 Does your amp have an overload feature on it or something? I know some amps have that....
Miakehl Posted February 5, 2010 Author Report Posted February 5, 2010 I'll go over it with my new DMM and see what I get out of it. The gain is goofy with the wires MTX sent with it...... EDIT: Added another video [HOONIGAN]* '01 Ford F-250 LWBJVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4
Miakehl Posted February 5, 2010 Author Report Posted February 5, 2010 Reset the gains with my DMM and it fixed the problem.. THANK YOU kirill007!!! [HOONIGAN]* '01 Ford F-250 LWBJVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4
kirill007 Posted February 5, 2010 Report Posted February 5, 2010 No problem, that's why this is such a cool place. Thinking is the root of all problems... You ALWAYS get what you pay for.
