:huh: They went outta business?
i thought the same thing?
DC.jpgDC POWER
Well yes they actually did. But they have been working hard trying to get everything back in order and now they are releasing there new series of subs. They ditched Audiopulse and will be staying TC Sounds as there name. A priceless has already been released as well.
An email i got from Julie about a month ago. Recently talked to her and she said they had move the release date to Feb. 8th.
"Hello,
Here is the latest information on our new products as of 12/10/09. We apologize for the delay but want to reassure you that it is well worth the wait.
Originally, we thought they would be ready to ship the first week of December. Due to some unforeseen material issues that date has changed to the end of January.
These are going to be the best speakers we have ever made. You will not be disappointed. We have a new superior assembly method for which we retooled the production line making each driver more precise. In addition, we have new packaging and a new packaging method. Now you will receive your motor separate from the top assembly. We will provide the screws and a wrench with instructions on how to assemble the top assembly to the motor.
There are numerous changes and improvements to each of the drivers, when compared to the current AudioPulse drivers on our website:
The Epic 10" and 12" have a larger shorting ring, a new spider design, and a high temperature stainless steel voice coil former to prevent eddy currents. The Epic is the only driver that will not have a detachable top assembly.
The Revo 12" and 15" are now called the LMS-R 12" and 15", it now have a 3" diameter LMS voice coil with stainless steel former, a shorting ring, a new dual 9.8" spider design, and a new detachable basket.
The Axis 12" and 15" have a longer winding length for even more linear excursion, and the 8-layer flat wound quad coil is wound on a stainless steel former with a very high temperature adhesive, giving it even more power handling. The spider has also been redesigned with quad leads in one spider for the highest durability.
The VMP’s are completely redesigned with a special injection molded thread and holder that are adhered to the new indestructible 1mm thick Aluminum cone, allowing for easy adjustment of the passive radiator mass by simply adding or subtracting steel washers.
The Pro 18" is a brand-new design that uses an enormous radial Neo motor with 3" long magnets, the largest radial Neo motor in production! The cone is a sandwich composite PMI/Rohacell with fiberglass/epoxy. This is probably the best high-efficiency high -excursion Pro Audio driver ever made! In addition, it will most likely find applications in high SPL car audio installations as well.
If you currently own an old Aura Neo speaker that has failed, we now have the perfect replacement assembly for you! We have a top assembly that simply bolts on, with performance surpassed only by our Pro 18".
The LMS Ultra 5400 is our top of the line low frequency driver and has a 4" diameter LMS voice coil, with stainless steel former, shorting ring, new 11" diameter dual spider design, detachable basket, and new assembly method.
Please hang in there. We appreciate your patience!"
there was a thread mentioning the comeback of TC
as far as i have read. TC made the best sub ever
took shit tons of power and sounded amazing, the 5400.
one day ill have TC i hope
this is exciting
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
this is exciting
148.8DB off a single TC-3000 with only 1200w rms.
Hopefully everything works out for them!
I have a 5400lms 15 in my closet...prices will determine if they stay around this time. im not paying 2k for a metal coned driver that i can slam the former through the cone
Edited by Forum Asshole
  • Who's Online   0 Members, 0 Anonymous, 926 Guests (See full list)
