(2) Ssa Icon 15d2's In A Santa Fe Lmtd
Amp: Kicker ZX1500.1
Subs: *** 15" trash (2)
Wire: Kicker 0 AWG amp kit
Batt: N/A
HU: Pioneer AVIC-D2
pics are here. here's the specs. 8cuft enclosure tuned to 35hz with 87sq.in. of port. Ports has been double routered for smooth air flow, Optima Yellow top installed in the back(more electrical upgrade coming soon). All 1/0 AWG kicker wire...anyways, here you go.
i'd like to add: this build took us 18hrs straight, not much sleep this weekend, and alot to trips to walmart for misc. tools.
Credits: I'd like to say none of this would have happened if it weren't for the "hella" lot of help and design of one of our forum members SHiZNiLTi, thanks Garret.
Posted Image
Posted Image
Here we dry fitted the box together to get the right perception of our project
Posted Image
Posted Image
here is an image of the double edge routered port
Posted Image
Posted Image
Posted Image
Posted Image
just showing how big this is by refrence to the sub here in this pic.
Posted Image
Posted Image
Posted Image
here's garett in the box, (6ft 7" tall!!)
Posted Image
here's what the truck looks like factory:
Posted Image
The cargo compartment is going to be removed, it's 8" deep and 45 wide! lots of more room
Posted Image
here the box is fitted in to the hatch area
Posted Image
here's our hella smooth port after being routered smooth
Posted Image
and the box before we attach the double baffle
Posted Image
Posted Image
adding glue to the baffle
Posted Image
Posted Image
Posted Image
holding it down is some serious weight, that big sub weighs 75 lbs. (it's also nailed)
Posted Image
the shop area
Posted Image
ah, the port! filed down smooth
Posted Image
Posted Image
Posted Image
over in the car, we're putting in the batt, wire, amp, etc...
Posted Image
Posted Image
Posted Image
Posted Image
and the dry fit of the box, almost there
Posted Image
this was at around 2am, total build time was 18hrs straight (you can see the sun coming up in further pics)
Posted Image
perfect fit, right to the seat line, yummy
Posted Image
Posted Image
the holes cut
Posted Image
Posted Image
zoomed out over view
Posted Image
the front batt terminal
Posted Image
Posted Image
the view from the back
Posted Image
Posted Image
Posted Image
and here is the finally pics we have before the box is painted and finished.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
well thats it. this build took us 18hrs straight, started at 1pm sat, and ended sunday morning late!
thanks again Garett!!!
looks good...now we need vids...
also if you do not have videos you will be banned..
jk bro
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
i know that's one loud suv man. i like how the enclosure sits down in that storage space ...... sort of gives the box more airspace than the eye can see. are you planning on doing the big 3?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
looks real nice, ima have to look at the sub over on *** so i can check out TS parameters
