ccrider540 Posted February 9, 2010 Report Posted February 9, 2010 Im building a new box and i was wondering if anyone knew how to wire up LED lights inside of a sub enclosure. I have no clue where to hook them up so they turn on with my amps. 1)Alpine CDA-117 1)hifonics brutus bxi 2610 1)hifonics zeus zxi6410 3)Alpine sps-600c 2)Fi BL d1 15s fully loaded
splzx3 Posted February 9, 2010 Report Posted February 9, 2010 + 2 the turn on the amp and ground 2 a ground ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
thehoe92 Posted February 9, 2010 Report Posted February 9, 2010 use a relay, perfect for multiple accessories Wouldnt be thehoe92 without teh purple
qu1cks1lver56 Posted February 9, 2010 Report Posted February 9, 2010 use a relay, perfect for multiple accessories . First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
rubbernutz1 Posted February 9, 2010 Report Posted February 9, 2010 ya use ur remote lead from the radio to turn a relay on and off. you dont wanna hook to muck stuff up to your remote lead cus you can fry it if ur not careful. use the relay to turn ur amps and what ever kind of lights ur gonna use on and off.
hotshot27 Posted February 9, 2010 Report Posted February 9, 2010 if you want the lights to flash, get a set of LEDS, do some math on the wattage, and tie them directly into the AC on your amp (speaker terminals) this will take some practice and you may blow a few sets before you get ehe perfect number of LEDS in series (if in doubt add too many and then remove them until desired brightness is achieved, this saves blowing a ton of them). if done properly, you will have a faint glowing when the bass hits at normal volume, and a full on light show at full tilt. Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN
Ben Building Posted February 9, 2010 Report Posted February 9, 2010 Just use a SPDT relay. Wire one end of the relay's coil to the remote turn-on and ground the other end. Wire one of the common leads of the relay to positive and the other side to the LEDs. Finally, ground the remaining lead of your LEDs and you're done. DO NOT wire your lights directly to your remote wire, even if it works (at first)!!
Miakehl Posted February 11, 2010 Report Posted February 11, 2010 SPDT SPDT stands for Single Pole Double Throw, BTW. Didn't know if you knew that so I figured I'd just toss it out there. [HOONIGAN]* '01 Ford F-250 LWBJVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4
joni13 Posted February 11, 2010 Report Posted February 11, 2010 if you want the lights to flash, get a set of LEDS, do some math on the wattage, and tie them directly into the AC on your amp (speaker terminals) this will take some practice and you may blow a few sets before you get ehe perfect number of LEDS in series (if in doubt add too many and then remove them until desired brightness is achieved, this saves blowing a ton of them). if done properly, you will have a faint glowing when the bass hits at normal volume, and a full on light show at full tilt. wtf are u talking about i dont see how that would work at all your impedance would be all kinds of messed up if u listen to that IMO you will burn ur car down RIP The 03 prix! New Ride 2003 Chevy Tahoe Z71 4 DC LVL 4 18s (2 currently installed) 2 DC PAI.2000 (1 currently installed) 1 DC PAI-120.4
