I DONT GET IT IM ABOUT TO SELL IT ALL!!!!
the amount of reserve doesnt matter if you cant properly charge it! youre getting low voltage because youre asking too much of your alt. small sedans dont create a great amount of power! if you had a sufficient power supply (alt), you wouldnt see voltage drop.
hhhmmm makes since... but still a brand new battery just dropped it in and getting low volt?
check all connections to amps and check power connections with a DMM.
what would this do? how would this help with my low volt cut out on JL amp
like i said its all new basicly i just ran all the zero gauge and 4 gauge and all new fuses and grounds and batterys
Thats so messy to read im not even going to try.
Have you done the big 3?
How are the amps and Batterys grounded?
i havent done the big 3 dont i need new battery terminals for that?
im not sure how to do the big 3
dont you replace the ground on alt replave the ground on battery terminal and like some ground to motor or something idk
did you properly set the gains with a DMM or oscope?
and i re read it, i didnt see where you said you did the big 3 to help voltage issues, that should be done as well.. maybe im just tired and didnt see it
no i havent done the big 3 maybe that will help?
did u give the alt a second to charge it fully? take it out on the highway without the stereo on for a min see if that helps
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
well, go get some 0g and do the big 3
http://www.stevemeadedesigns.com/board/ind...showtopic=13280
thats the tutorial
go get a DMM and set your gains with
I posted everything you need to do...
Team_DC-Derrick's Youtube
Team DC Audio
A. Big 3 in 0/1 up front.
B. 0/1 Ran from front to back fused at both ends to each battery.
C. Then run 0/1 to the distro block from the battery for the amps.
D. Run all wires to the respective amps.
no big 3 yet...
front yellow top + term zero gauge to a 250 anl fuse block then zero out the other side of fuse block
then zero to the back to a fused dual anl distro block
then from other side of fused distro 2 sets of 4 gauge
one set of 4 gauge go's from distro to a kinetik hc800 then
on the kinetik theres a zero gauge ground on neg post that go's to body
then 4gauge ground off neg post on kinetik to the jl 1000/1v2
then on the pos term on kinetik is 4 gauge coming from distro block then 4 gauge back to jl amp
the other 4 gage from disrto block go's to the arc audio door speaker amp so 4 gauge in to the arc amp and 4 gauge ground out of arc amp to the body
  • Who's Online   0 Members, 0 Anonymous, 1606 Guests (See full list)
