ch0sen Posted February 9, 2010 Report Posted February 9, 2010 all that equipment and no volt meter lame And i agree, 0 gauge grounds for starters and go from there My current 95 Jetta Build w/ pioneer h/u 2 RD Sonance 10's with flatwind coils 2 Audiopipe apsm 1500.1s 1 Hifonics Brutus Elite 60x4 1 XS d925 1 Stinger spv35 1 1000 amp lead acid 50 ft of 0/1 ofc from Audiotechnix all powerbass components, and coaxils, 4 sets buildlog = http://www.stevemead...2-rd-10s-build/ My build for my wife. http://www.stevemead...01-f-150-build/
czman30 Posted February 9, 2010 Report Posted February 9, 2010 What kind of power wire are you using? And are you running four gauge to the 1000/1? he's using 0 gauge for the jl amp then 4 gauge for the mid's and highs And his problem is he needs a new alternator like atleast a 200 amp then he will be good Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol
SVT4LIFE Posted February 9, 2010 Author Report Posted February 9, 2010 hes using 4 gauge for the power on the mids amp from the batt in the back.. no zero from the batt up front to a splitter to 2 four gauge and the hc800 is only hooked up to the jl 1000/1 and brand new batt up front yellow top D35 deep cycle just got it like an hour ago the door speaker amp the arc audio isnt running a 2nd battery its only running off the one under the hood
SVT4LIFE Posted February 9, 2010 Author Report Posted February 9, 2010 he's using 0 gauge for the jl amp then 4 gauge for the mid's and highsAnd his problem is he needs a new alternator like atleast a 200 amp then he will be good it go's zero from up front under hood to the back then theres a fused anl splitter that the zero plugs into then on the other side of the splitter is 2 four gauge both amps in the back are getting 4 gauge its just that the jl 1000/1v2 has an extra battery a kinetik HC800 for just the JL the kinetik is not hooked up to the arc audio amp for my doors
Sable Nave Posted February 9, 2010 Report Posted February 9, 2010 he's using 0 gauge for the jl amp then 4 gauge for the mid's and highsAnd his problem is he needs a new alternator like atleast a 200 amp then he will be good That's not necessarily the case Car 1996 Sable LS 8,000K Bi-Xenon HID's Pioneer Premier DEX-P1R Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4 Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001 Dynamat Dynaliner Second Skin Damplifier Pro Stock 130A Alternator My Build Truck 1995 Ford F-150 Flareside XLT 10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F Truck Build Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman [speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it [capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes [KevinniveK] can u have sex later please hes helping me
Team_DC-Derrick Posted February 9, 2010 Report Posted February 9, 2010 well, go get some 0g and do the big 3 http://www.stevemeadedesigns.com/board/ind...showtopic=13280 thats the tutorial go get a DMM and set your gains with The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
Sable Nave Posted February 9, 2010 Report Posted February 9, 2010 it go's zero from up front under hood to the backthen theres a fused anl splitter that the zero plugs into then on the other side of the splitter is 2 four gauge both amps in the back are getting 4 gauge its just that the jl 1000/1v2 has an extra battery a kinetik HC800 for just the JL the kinetik is not hooked up to the arc audio amp for my doors Swap out the 4awg for 1/0awg on the JL and see if it helps Car 1996 Sable LS 8,000K Bi-Xenon HID's Pioneer Premier DEX-P1R Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4 Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001 Dynamat Dynaliner Second Skin Damplifier Pro Stock 130A Alternator My Build Truck 1995 Ford F-150 Flareside XLT 10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F Truck Build Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman [speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it [capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes [KevinniveK] can u have sex later please hes helping me
SVT4LIFE Posted February 9, 2010 Author Report Posted February 9, 2010 all that equipment and no volt meter lameAnd i agree, 0 gauge grounds for starters and go from there i have one zero gauge ground the zero gauge ground i have is on the kinetik HC800 on the neg post to the body then the other neg wire on the kinetik is 4 gauge going to the jl 1000/1v2 and the arc audio amp for my doors has a 4 gauge ground to the body both have good metal to body grounds
dugee81 Posted February 9, 2010 Report Posted February 9, 2010 the amount of reserve doesnt matter if you cant properly charge it! youre getting low voltage because youre asking too much of your alt. small sedans dont create a great amount of power! if you had a sufficient power supply (alt), you wouldnt see voltage drop. 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
SVT4LIFE Posted February 9, 2010 Author Report Posted February 9, 2010 Swap out the 4awg for 1/0awg on the JL and see if it helps the jl dosent accept zero gauge it wont fit
