jesterjames Posted February 10, 2010 Report Posted February 10, 2010 hhhmmm the bottom of my rear seat folds up and the body of the car i took the paint off it and grounded it to the body? on both ampsif i found a better ground would it allow or create more voltage? That might be suitable ground, what you want to avoid is grounding to thin areas of sheet metal. Areas that support anything generally have a decent amount of steel to ground to. More or less if you grounded to straight sheet metal than you can probably do better, if you grounded to say where the seat belts bolt down or where the seat support runs. Than you should be good. At this point pictures would be very helpful, not just of the grounds, but also of how the wiring is routed Pioneer 500UB 1 LVL4 15" 4.3cubes tuned to 35HZ BXi1606D 1/0 Red top in back JBL 5 1/4's front Infinity Kappa 6 1/2's rear 145.7 Legal on music New Audio Control
SVT4LIFE Posted February 10, 2010 Author Report Posted February 10, 2010 Please watch this so you understand what we're talking about for the big 3, once that is done you run your 0/1 to the back battery then hook those amps to the back battery and VIOLA your done. so the big 3 should help my volt drop on the jl amp?
Bunker Posted February 10, 2010 Report Posted February 10, 2010 Big 3 and alternator and your good to go. Look at your electrical like this. A straw equals 8 gauge. Get a straw and close your nose and try breathing through it. It will be difficult. Now think of breathing normal is 0 gauge no were near as hard and your system thanks you for giving it the Big 3. J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer
Skullz Posted February 10, 2010 Report Posted February 10, 2010 The big 3 helps BIG TIME on voltage drop. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
SVT4LIFE Posted February 10, 2010 Author Report Posted February 10, 2010 That might be suitable ground, what you want to avoid is grounding to thin areas of sheet metal. Areas that support anything generally have a decent amount of steel to ground to.More or less if you grounded to straight sheet metal than you can probably do better, if you grounded to say where the seat belts bolt down or where the seat support runs. Than you should be good. At this point pictures would be very helpful, not just of the grounds, but also of how the wiring is routed ill do a youtube vid and post the link on here but i did do the grounds to kinda think sheet metal you think if i found a better gound there would be less voltage drop? ill go do the vid right now!! no bs everybody stick around please lol i need all the help i can get lmfao
SVT4LIFE Posted February 10, 2010 Author Report Posted February 10, 2010 where are the cliff notes? what are cliff notes lol is that what the problem is if so voltage drop on bass amp with all new wires fuse and batts gonna make a vid be back soon with a vid i have upload it too
jesterjames Posted February 10, 2010 Report Posted February 10, 2010 well see i dont think that battery is enough for both amps this is why i have it wired like thisand i most likely going to add another kinetik HC1800 this weekend so the HC800 will get wired to the doors amp then the HC1800 will go to the JL 1000/1v2 To be dead honest, I would just run the + and - from battery to battery and screw the ground on the chassis. You are completing the circuit either way. And a better ground would be a drilled hole, sanded, to the actual chassis.I'm willing to bet there's a bottleneck of power from front to back. Have you tried just eliminating the back battery with the current setup? PS You NEED a voltmeter. Batterys work together, im actually going to draw you a picture since your not understand what were saying. And to Neo, running a separate run of 1/0 from front to back is not necessary in this case. Also his car is Unibody so there is no "frame" per say Both batterys are to be grounded to the body of the car Pioneer 500UB 1 LVL4 15" 4.3cubes tuned to 35HZ BXi1606D 1/0 Red top in back JBL 5 1/4's front Infinity Kappa 6 1/2's rear 145.7 Legal on music New Audio Control
Dro Posted February 10, 2010 Report Posted February 10, 2010 so the big 3 should help my volt drop on the jl amp? it will help both amps trailblazer 18" xl aq2200 147.8db at 4 ohms
jesterjames Posted February 10, 2010 Report Posted February 10, 2010 ill do a youtube vid and post the link on here but i did do the grounds to kinda think sheet metalyou think if i found a better gound there would be less voltage drop? ill go do the vid right now!! no bs everybody stick around please lol i need all the help i can get lmfao ground is crappy term in a way, people think of it the wrong way sometimes. Appropriately called Negative in this demonstration. Your battery is your vehicles ground. Power flows from positive to negative. To cut corners and manufacturing costs car makers run only power wire in the vehicle. The cars frame or body is attached to the negative side of the battery making the body of your car the "ground" In short, the better the connection between the + and - side of the battery the less voltage drop Pioneer 500UB 1 LVL4 15" 4.3cubes tuned to 35HZ BXi1606D 1/0 Red top in back JBL 5 1/4's front Infinity Kappa 6 1/2's rear 145.7 Legal on music New Audio Control
SVT4LIFE Posted February 10, 2010 Author Report Posted February 10, 2010 Batterys work together, im actually going to draw you a picture since your not understand what were saying.And to Neo, running a separate run of 1/0 from front to back is not necessary in this case. Also his car is Unibody so there is no frame. Both batterys are to be grounded to the body of the car i just wen to make a quick vid but my camera was dieing so give it a few min to charge up a little and then i will make a quick vid for all of you too see so give me a few min and it should help out a little
