LoudNLow931 Posted February 15, 2010 Report Share Posted February 15, 2010 So I bought this blazer for the original owner who I still talk to often, and after about 2 weeks of driving it(When It started to get cold out here) I was driving to my dads work to drop something off and the light came on. I brought it to a local shop and had it checked out, He said he seen nothing wrong and ran the little computer check thing and nothing came up so he cleared the light and said if it came back on to bring it up there again. So A few weeks went by and on another cold night I turned the heat on again bam light came on again. At first I didn't put two and two together but now that I remember both times when I cranked the heat it came on. My dad thinks it may need new vent hoses what else could it be? The truck runs great and doesn't stall or anything, Doesn't get very cold here often(So the heat wasn't used often) but in the summer it does get hot and its a black truck so something could have happened to the hoses? Thanks for any help. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback Link to comment Share on other sites More sharing options...
BeatBox Posted February 15, 2010 Report Share Posted February 15, 2010 gas cap? mine kept doing that, turning on and on. bought a new cap and still did it. I took it to autozone and thats wut code it kept showing. finally pissed me off enough i just took the bulb out ;-) Link to comment Share on other sites More sharing options...
LoudNLow931 Posted February 15, 2010 Author Report Share Posted February 15, 2010 I try'd that also, When I brought it to auto zone a code came up for a purge solenoid value when I got the part it wasn't even on my truck haha. The guy at the shop I go to said the throttle body might need to be cleaned. The chevy dealer wants hella money to check it out, I might have him clear the light again and see if it come back on when I crank the heat. Its not bothering how it runs So I'm not to worried. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback Link to comment Share on other sites More sharing options...
Mr. Ben Posted February 15, 2010 Report Share Posted February 15, 2010 I try'd that also, When I brought it to auto zone a code came up for a purge solenoid value when I got the part it wasn't even on my truck haha. The guy at the shop I go to said the throttle body might need to be cleaned. The chevy dealer wants hella money to check it out, I might have him clear the light again and see if it come back on when I crank the heat. Its not bothering how it runs So I'm not to worried. couldjust be a dirty intake sensor start to worry when it doesnt hold an idle but if you get the actual codes from auto parts store then you can google the codes and narrow down the problem BIG PYMPIN IS BIG PYMPIN IS BIG PYMPIN Link to comment Share on other sites More sharing options...
LoudNLow931 Posted February 15, 2010 Author Report Share Posted February 15, 2010 couldjust be a dirty intake sensor start to worry when it doesnt hold an idle but if you get the actual codes from auto parts store then you can google the codes and narrow down the problem They ran the check thing like auto zone has at my local shop and nothing came up... 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback Link to comment Share on other sites More sharing options...
Mr. Ben Posted February 15, 2010 Report Share Posted February 15, 2010 They ran the check thing like auto zone has at my local shop and nothing came up... maybe like in my car my thermostat was stuck with gunk cause the previios owner never changed the coolant and my engine read different temps so it kept throwing my light on wierd? tho that and a loose harnes next to my battery kept throwing the light but same thing no codes my car is a 02 impala BIG PYMPIN IS BIG PYMPIN IS BIG PYMPIN Link to comment Share on other sites More sharing options...
actafool4187 Posted February 15, 2010 Report Share Posted February 15, 2010 i have an '02 sonoma. i call this my winter ses light. with the heat on, the light comes on. during summer with ac, no light. since my temp guage isn't too hot or too cold, i'm not worried about it Pioneer AVH P5900DVD JL Audio XR525 CSi Components (Kickpanels) Infinity Reference 6020cs Components (Doors) JL Audio 12W7 Subwoofer JL Audio e1800D Amplifier JL Audio e4300D Amplifier Link to comment Share on other sites More sharing options...
wL<3bass Posted February 15, 2010 Report Share Posted February 15, 2010 Mine does it too.... except mine throws a code for an O2 sensor, which aren't bad (they are all new) only does it on cold days when it has to idle for 15min to warm up.... I got to the point I don't even care about it anymore lol. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references... Link to comment Share on other sites More sharing options...
LoudNLow931 Posted February 15, 2010 Author Report Share Posted February 15, 2010 So its sounds like its nothing and I shouldn't worry about it. I'm going to have him reset it again then I'll crank the heat and see if it does it again. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback Link to comment Share on other sites More sharing options...
Destram Posted February 16, 2010 Report Share Posted February 16, 2010 Hmm..my service engine light has been coming on the past week or two, but it goes off, too. It'll come on, then it'll be off the next day when I get in..then it'll come on that night or some other day, but it'll go off again. I've been meaning to take it to get the computer hooked up on it. 2006 BMW 325i My feedback: http://www.stevemeadedesigns.com/board/topic/77301-official-destram-feedback/ Link to comment Share on other sites More sharing options...
