czman30 Posted February 17, 2010 Report Share Posted February 17, 2010 Amps are behind a wall no AC access. well u need to find a way to get AC to the amps then you should be able to cool the amps well Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol Link to comment Share on other sites More sharing options...
czman30 Posted February 17, 2010 Report Share Posted February 17, 2010 Well Just Put a portable cooler in the back with ice then leave it open then problem solved :D Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol Link to comment Share on other sites More sharing options...
Bunker Posted February 17, 2010 Author Report Share Posted February 17, 2010 what impediance are you running your sub(s) at? and check your ground make sure its up to par to handle the power 1ohm 1/0 power to buss bar, 1/0 ground to buss bar and grounded to frame, amps 2 gauge wont except 1/0 J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer Link to comment Share on other sites More sharing options...
Loudcivic Posted February 17, 2010 Report Share Posted February 17, 2010 my 1500d runs good i have no issues at all. you need some ventilation for them. you cant just put them in a small area with no air flow. most amps would overheat if you put it in a space with no airflow and not much space 2015 silverado crew cab nothing atm but soon... Link to comment Share on other sites More sharing options...
R_Mac_1 Posted February 17, 2010 Report Share Posted February 17, 2010 Lol put a fan on it or I gotta a better idea Put THe AC ON DUH :D WELL DUH THATS YOUR PROBLEM THERE LOL well u need to find a way to get AC to the amps then you should be able to cool the amps well Well Just Put a portable cooler in the back with ice then leave it open then problem solved :D Seriously dude, you are a moron. If you don't know what you're talking about or have anything to add to the conversation, why even post? 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M Link to comment Share on other sites More sharing options...
uhoh_45 Posted February 17, 2010 Report Share Posted February 17, 2010 1ohm 1/0 power to buss bar, 1/0 ground to buss bar and grounded to frame, amps 2 gauge wont except 1/0 safe to say your good there your not runnin to low of an ohm load and you've got a solid ground so it must be ventilation are your amps stacked? or real close to eachother? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
newls1 Posted February 17, 2010 Report Share Posted February 17, 2010 Seriously dude, you are a moron. If you don't know what you're talking about or have anything to add to the conversation, why even post? WELL SAID! czman30.......consider this a warning. STOP your BS postings, or have a nice vaca, YOU CHOOSE WHAT YOU WANT! I love my staffie So anti FACEBOOK it isn't even funny Link to comment Share on other sites More sharing options...
Bunker Posted February 17, 2010 Author Report Share Posted February 17, 2010 safe to say your good there your not runnin to low of an ohm load and you've got a solid ground so it must be ventilation are your amps stacked? or real close to eachother? Not stacked. When I get all 4 they will have about 6in all the way around each other. I'll get a picture. J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer Link to comment Share on other sites More sharing options...
Bunker Posted February 17, 2010 Author Report Share Posted February 17, 2010 http://s486.photobucket.com/home/CoachBunker/index J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer Link to comment Share on other sites More sharing options...
wildcard4040 Posted February 17, 2010 Report Share Posted February 17, 2010 Think your gonna have to hook up some fans man. Looks like a tight fit. You can get some little computer fans for pretty cheap and just run them on a duckbill switch. i think i just gave myself a concussion i facepalmed so hard. and for the 1's that dont like me..... well, Im still here fuckers. Cant get rid of me that easy. Link to comment Share on other sites More sharing options...
